M-Spec, N1, Nur R34's
Production :
Standard - 3,962
Vspec/Mspec - 7,338
N1 - 45
By Year:
1999 - 5536
2000 - 1859
2001 - 2197
2002 - 1775
2003 - 2
Total Production: 12,175
but you have to minus a few because of people smashing them to an unrepairable state.
ill post somemore info after i find the website that i need.
edit : oh and the search button is not an enemy
they were probably build forthe sake of going into the museum.
well i got the info.
V-Spec :
The V-spec is the flagship model of the GT-R range. to increase performance an active LSD controlled in conjunction by a viscous coupling is used.
To aid high speed stability and overall road handling stiffer suspension and aerodynamics parts were implemented.
Special front and rear diffusers were developed, the rear one constructed from carbon fibre.
Difference from Standard :
Brake air duct
Front diffuser
Rear carbon diffuser
Active LSD
ATTESA E-TS PRO
Hard suspension
V-Spec II :
The V-spec was replaced with the V-spec II on August 28th, 2000.
The original aluminium bonnet has been replaced by a carbon fibre item with NACA duct to aid engine cooling
Furthermore the interior trim is now realised in black cloth and the rear brake discs are now slightly bigger (same as the N1 version).
Due to revision of the colour line-up, the following light colours are so far available: Bayside Blue (#TV2), White (#QM1), and White Pearl (#QX1). Silver and black are also available, but yellow and red are not available any more.
Difference from V-spec :
Rear brake (N1 based brake caliper)
Aluminum sport pedal (Axcel, Brake, Cluth)
Trim colour (from gray to black)
Carbon bonnet with NACA duct
White repeater lense
Colour of center console
Add: White Pearl(#QX1), Sparkling Silver(#WV2)
Del: Lightning Yellow(#EV1), Active Red(#AR2), Sonic Silver(#KR4
M-Spec :
The M-spec is an additional BNR34 GT-R model which has been on sale since May 8th, 2001.
It sports a set of new comfort-developed shocks (called "Ripple-Control"), leather trim, soft and fine grip steering wheel, and aluminium bonnet.
This car represents the luxury version of the GT-R with performance almost equal to the V-spec II.
A special colour has also been developed for this new model. It is called "Champagne-Gold"(Multi-Flex Colour) (#EY0).
Other colours in the line up besides the Champagne Gold (#EY0) include: Black Pearl Metallic (#GV1), Sparkling Silver (#WV2), and White Pearl (#QX1).
Because of the extensive time needed to complete the hand sewn leather trim interior, only a limited edition of 50 cars per month will be made.
Difference from V-specII :
Leather trim with gold stitch
Seat heater (Fr)
Ripple-Control shock absorber
Softened stabilizer
Softened steering wheel (Fine-grip type)
Aluminum bonnet (Option : Carbon bonnet)
Exclusive colour : Champagne-Gold (#EY0)
Did the M-Spec get the N1 engine???
its hard to find info on the N1 as there arnt many around but this is what i could find.
they only came in white with an unpainted carbon fibre bonnet.
The N1 is a spartan race car, designed to participate in N1 races.
Special equipment :
Twin ball bearing metal turbo-chargers
Extra large, air-cooled engine oil cooler
The main equipment deleted from the GT-R V.spec II :
Rear intermittent wiper
Rear fog lamp
Remote control entry system
Passenger's seat vanity mirror
Clean air filter
AM/FM electronic radio and CD player (equipped with aerial and wiring loom.)
Glove box damper & glove box lamp
Super-fine hard coat paint.
Equipment changes to GT-R V.spec II
UV cutting insulation and front door green glass --> green glass
Side indicator lamp --> reflector
Colour coded electric folding door mirror mount & body --> painted black
Leather hand brake lever --> resin
Leather centre console lid --> resin
Full auto air conditioner --> heater, with outside temperature display
¤ The N1 does not have any manufacturer's options. Note: The transmission, rear differential and transfer box oil coolers are all made by Nismo. The intercooler's carbon air guide is a dealer option.
¤ The body is only available in white <#QM1> and the carbon fibre bonnet comes unpainted.
i duno i saw the N1 while flipin thro the latest HPI GTR Special
Yes, it did. The M-Spec Nur, and the V-Spec II Nur both got the N1 balanced engine with N1 conrods, pistons and crank, topped off with the gold cam cover.
i cant understand why its so expensive.
how much better (faster) is the n1 from the normal V-spec
The only major change i can think of is the N1 rb26dett. the rest is just exterior and interior things.
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
