Production :
Standard - 3,962
Vspec/Mspec - 7,338
N1 - 45
By Year:
1999 - 5536
2000 - 1859
2001 - 2197
2002 - 1775
2003 - 2
Total Production: 12,175
but you have to minus a few because of people smashing them to an unrepairable state.
ill post somemore info after i find the website that i need.
edit : oh and the search button is not an enemy
they were probably build forthe sake of going into the museum.
well i got the info.
V-Spec :
The V-spec is the flagship model of the GT-R range. to increase performance an active LSD controlled in conjunction by a viscous coupling is used.
To aid high speed stability and overall road handling stiffer suspension and aerodynamics parts were implemented.
Special front and rear diffusers were developed, the rear one constructed from carbon fibre.
Difference from Standard :
Brake air duct
Front diffuser
Rear carbon diffuser
Active LSD
ATTESA E-TS PRO
Hard suspension
V-Spec II :
The V-spec was replaced with the V-spec II on August 28th, 2000.
The original aluminium bonnet has been replaced by a carbon fibre item with NACA duct to aid engine cooling
Furthermore the interior trim is now realised in black cloth and the rear brake discs are now slightly bigger (same as the N1 version).
Due to revision of the colour line-up, the following light colours are so far available: Bayside Blue (#TV2), White (#QM1), and White Pearl (#QX1). Silver and black are also available, but yellow and red are not available any more.
Difference from V-spec :
Rear brake (N1 based brake caliper)
Aluminum sport pedal (Axcel, Brake, Cluth)
Trim colour (from gray to black)
Carbon bonnet with NACA duct
White repeater lense
Colour of center console
Add: White Pearl(#QX1), Sparkling Silver(#WV2)
Del: Lightning Yellow(#EV1), Active Red(#AR2), Sonic Silver(#KR4
M-Spec :
The M-spec is an additional BNR34 GT-R model which has been on sale since May 8th, 2001.
It sports a set of new comfort-developed shocks (called "Ripple-Control"), leather trim, soft and fine grip steering wheel, and aluminium bonnet.
This car represents the luxury version of the GT-R with performance almost equal to the V-spec II.
A special colour has also been developed for this new model. It is called "Champagne-Gold"(Multi-Flex Colour) (#EY0).
Other colours in the line up besides the Champagne Gold (#EY0) include: Black Pearl Metallic (#GV1), Sparkling Silver (#WV2), and White Pearl (#QX1).
Because of the extensive time needed to complete the hand sewn leather trim interior, only a limited edition of 50 cars per month will be made.
Difference from V-specII :
Leather trim with gold stitch
Seat heater (Fr)
Ripple-Control shock absorber
Softened stabilizer
Softened steering wheel (Fine-grip type)
Aluminum bonnet (Option : Carbon bonnet)
Exclusive colour : Champagne-Gold (#EY0)
Did the M-Spec get the N1 engine???
its hard to find info on the N1 as there arnt many around but this is what i could find.
they only came in white with an unpainted carbon fibre bonnet.
The N1 is a spartan race car, designed to participate in N1 races.
Special equipment :
Twin ball bearing metal turbo-chargers
Extra large, air-cooled engine oil cooler
The main equipment deleted from the GT-R V.spec II :
Rear intermittent wiper
Rear fog lamp
Remote control entry system
Passenger's seat vanity mirror
Clean air filter
AM/FM electronic radio and CD player (equipped with aerial and wiring loom.)
Glove box damper & glove box lamp
Super-fine hard coat paint.
Equipment changes to GT-R V.spec II
UV cutting insulation and front door green glass --> green glass
Side indicator lamp --> reflector
Colour coded electric folding door mirror mount & body --> painted black
Leather hand brake lever --> resin
Leather centre console lid --> resin
Full auto air conditioner --> heater, with outside temperature display
¤ The N1 does not have any manufacturer's options. Note: The transmission, rear differential and transfer box oil coolers are all made by Nismo. The intercooler's carbon air guide is a dealer option.
¤ The body is only available in white <#QM1> and the carbon fibre bonnet comes unpainted.
i duno i saw the N1 while flipin thro the latest HPI GTR Special
Yes, it did. The M-Spec Nur, and the V-Spec II Nur both got the N1 balanced engine with N1 conrods, pistons and crank, topped off with the gold cam cover.
AnthonyK1 - theres a midnight purple R34 N1 for sale on www.carsales.com.au.
Powerplay in Syd recently had a NUR for sale - nice @$170K. For the $80K you could save on a 99 V Spec you'd have to have too much money to get it.
