AnthonyK1 - theres a midnight purple R34 N1 for sale on www.carsales.com.au.
Powerplay in Syd recently had a NUR for sale - nice @$170K. For the $80K you could save on a 99 V Spec you'd have to have too much money to get it.
I called this guy up. It's not an N1. It's been modified using N1 parts but not a genuine N1. The colour is wild but. That alone is worth the mint. The price sometimes does not reflect the performance difference but the rarity of it. This "puple haze" colour is wild and apparently only 50 was release as limited. I wanted this colour when I got my car but they couldn't get it so I settled for black.
Brand new GTRs also varied in the colours you choose. I think when it was first release, the purple was the most expensive, followed by the black, then the yellow then the blue....I think in that order.
If you throw enough money at any GT-R you can make it better than an N1.
But there were only 228 real R32 GT-R N1 Skylines.
There were thousands of plain GT-Rs. The rarity value is what makes it expensive.
I would imagine the Japanese do not want to relinquish their N1s seeing as that they are so prized by collectors and race people.
T.
The colour is midnight purple II and midnight purple III...LV4 and ummm not sure of the second one....there was 300 of each.....a friend of mine has one in melbourne...he has LV4(midnight purple II)he also has a front bar off a midnight purple III...the original is a better colour its a green harlequin instead of a blue
M-spec for me please. Evo magazine in GB rated it better than the TT 911 AWD they love so much after slagging V-spec's that didn't like their roads. Said it was outpacing it by 20kmh on one crest curve combo and felt like it had more to give with the flash ripple control suspension MMMMMmmmmmmmm
Hi Folks,
May have found one of the 03 GTR V-Specs. Check this out, its actually for sale with only 25 miles on the clock...
Go to http://www.middlehurst.co.uk/ and enter site, select skyline under the approved used cars drop down, and before you a link will appear to a page on the car. Click the link...
This website is the official UK nissan GTR dealer. I wonder if its still available...
Then again, I also wonder if its really a 03 car.
Time to move to UK anyone?
Hi Folks,
http://eclipse.usp.net/motorstock/middlehu...o.cfm?frmID=177
Definitely NOT an official Japanese '03 model.
How can it be one of the two '03 models if it's #53 of an official 80 numbered UK spec cars?
It's an '03 UK plate for sure but it looks like a Japanese '99 Series 1 which has been modified to 'UK spec'. Sure it's got 25km on it... it's spent the last few years under wraps.
The front indicators are still orange and it's not one of the items changed.
T.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
