Anyone had a gearbox rebuilt locally and if so by whom, any bad experiences pm me. I am thinking of talking to southern differentials. As i have had work done there.
Car has a stuffed transfer case at the moment, and the gearbox isn't the greatest, so thinking of a rebuild or perhaps going to an r33 gtr gearbox. Also does anyone know of any rebuild kits out there?
https://www.sau.com.au/forums/topic/329680-gearbox-rebuild/
I currently have an R33 GTR gearbox in mine. Second is a bit crunchy. I'll be rebuilding this box at some stage with the OS Giken kit and maybe a hollinger shaft. Interested in this, I haven't decided who will do this for me yet.
https://www.sau.com.au/forums/topic/329680-gearbox-rebuild/#findComment-5356558
Yeah saw it there yesterday, Just saw somone pull up in a 4wd and trailer and saw this thread...put them together...but alas I was wrong,
As Blitzxtr prob said, Award Diff and Gearbox have runs on the board but they are a fair hike from Canberra.
https://www.sau.com.au/forums/topic/329680-gearbox-rebuild/#findComment-5356660
yeah Terry reuilds these things in between spoonfuls of weetbix during breakfast. He did the PPG helical dog in my car and its mint. He also knows just what bits need ordering when doing OS conversions as the bits required are not always the same. This seems an issue with other shops doing OS boxes, handing the customer a notchy noisy box and telling the customer that its noisy and notchy due to the gearset. OS gearsets when installed correctly using the right list of update parts do not whine or are notchy, they shouldn't even be able to pick it from a stocker.
He also does transfer cases.
Edited by blitzxtr
https://www.sau.com.au/forums/topic/329680-gearbox-rebuild/#findComment-5356707
Well Ive decided I will be getting the box rebuilt at award when the parts come in, just a standard rebuild to r33 specs. In the scheme of things it's not that much more expensive than getting a 2nd hand gtr box, which is a bit of a lottery. The local places don't seem to have the experience with these boxes that Terry has.
https://www.sau.com.au/forums/topic/329680-gearbox-rebuild/#findComment-5368591
about 1400$ in parts plus labour of taking the box out and rebuilding it.
replacing:
input shaft, 2nd synchro ring, 3rd synchro ring, 4th synchro ring, 1st/2nd selector sleeve, 3rd, 4th selector sleeve, 3rd/4th selector hub,
Energiser springs & pads for 1st/2nd/3rd/4th
https://www.sau.com.au/forums/topic/329680-gearbox-rebuild/#findComment-5368914
  • 5 weeks later...
Well have the car back now, and overall happy. A few things though, be prepared for a few weeks without the car just incase. Due to the wrong parts being delivered twice by nissan, my job took 2 and a half weeks. Box overall feels nice and smooth, does feel a bit different to shift than other r32 boxes ive tried. I think this might be due to the hks short shifter in the car, would be interested in seeing what another box with a short shifter feels like. Finally got rid of my bearing noise as well.
p.s don't let your transfer case run out of oil lol, thats what happened to mine, i feel retarded.
https://www.sau.com.au/forums/topic/329680-gearbox-rebuild/#findComment-5423390
Hey Chris,
You can have a drive of mine one day soon, I have a TOMEI short shifter in my RB25 box... Should be a good comparison, although my box isnt exactly new. :)
Don't necessarily have to drive it, just want to check the throw and the feel compared to mine, even just going through the gears when the car is off I can tell the feel is different to a normal shifter. Happy to let you test drive mine if you want in return.
https://www.sau.com.au/forums/topic/329680-gearbox-rebuild/#findComment-5427393
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
