Howdy!
So, I have been getting around in grandpa's old stock as a rock r31. Things were going well, but I ran it low on fuel and it ran poorly for 30 seconds and died. I actually thought I had run out of fuel, so I topped the sucker up and it ran again.
Then it stopped running again the next day.
I drained the fuel tank, added injector cleaner and changed the fuel filter, and the car ran like a champ. Then it stopped again after 20 mins.
I decided I must have fouled the fuel pump and (being the weekend) I organised a couple of crappy 2nd hand fuel pumps, and the car ran again. Then it stopped again.
So I tried the other spare fuel pump and that went well for another 20 odd kms then it stopped. Again.
If I disconnect the fuel line at the filter when I start the car fuel sprays out everywhere. After a short drive the car dies, and when I disconnect the fuel line I get no fuel spraying anywhere. However, if I wash the car, or go for a couple of beers, or sit around for a couple of hours the fuel starts pumping again, and I can drive another few kms before breaking down again.
Do I have (now 4) dodgey used fuel pumps, that only work sometimes, or is there another problem - maybe like a bad earth, that causes the pumps to cut out sometimes then come back to life after a bit of a break.
Thanks.
https://www.sau.com.au/forums/topic/329695-r31-intermittent-fuel-problems/
Drew,
I would be looking at the Fuel Pressure Reg & if that's not the issue try the injectors, but both of these don't explain the lack of fuel at the filter.
I had a similar problem with the KHR30 and I fixed it by chucking out both the old fuel pump and pressure regulator. Now it goes like a dream with a 910 copy fuel pump & right angle banjo fittings.
The R31 has an in tank pump set up, correct? If this is the go, look at the filter sock on the end of the pump, as todays unleaded fuel turns to nearly acid when it sits for a while and starts eating the fuel tank. The sock might have some rust & shit in it that blocks it up occassionally.
Cheers, D
Not even sure what a fuel pressure regulator is, but I'll look it up and try swapping it. The sock on the end of the in-tank filter looks ok. Besides, the problem is affecting multiple fuel pumps/filter socks, and at a glance they all look right.
When you drained the tank, did you get much crap out of it and did you stick a hose in it and wash it out? When I first brought the purple DR to Sydney, what we got out of the tank was brown and we washed it out with a hose and let it dry out and then fitted a pre filter to be sure what was going into the pump was clean fuel. Works sorta like an intank filter sock.
Cheers, D
Actually the fuel looked pretty good, so I only drained, and didn't flush. Flushing and prefilter sound like saavy ideas. The r31 guys are suggesting that my crank angle sensor may be sending bad info to the ECU about when to send fuel. I'm going to try that, too. Apparently they are vunerable to malfunction when hot.
I heard of a similar story years ago with a Patrol. Long story short, there was a piece of plastic floating around in the fuel tank. Every now and then it would block the fuel pickup. After stopping the engine, the plastic would float away and everything would be OK until the next time.
As Dennis suggested, you might need to give the tank a really good flush.
Can't see the CAS stopping the pump, though.
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
