R33 Gtr Gearbox.
Hey Guys,
well i have just had my gearbox in my R33 GTR overhauled with new synchro's on 2-4 gears and jap bearings throughout. I have been thinking about it the whole time it was out and have decided to go a different direction with the car now so the freshly rebuilt box is going up for sale.
box is back in the car now as i know how hard it will be for someone buying a gearbox not knowing what there getting. this way you can come and see what your getting. Gearbox has tiny bit of roll-over noise as all rebuilt boxes do but i can assure it was rebuilt by proffesional diff and gearbox company in melbournes south east suburbs.
rebuilt gearbox's on the net are $1300 CHANGEOVER so i think this is worth $2,300 outright as its as new condition. comes with transfer case too.
located in SE suburbs of Melbourne and possible buyers are welcome to come inspect. i am also able to help with freight AUS wide at very good price if its required.
any questions please ask via PM..
Chris
  • 5 weeks later...
sorry guys, after add being on here for a long time i have only just realised that i said it comes witht he transfer case too,
i would like to mention that this is for gearbox only, no transfer case but i have dropped the price to $2,000 too so that should make someone happy.
  • 3 weeks later...
lol mate i was joking i know my prices very well ;) hopefully you do sell it :D
oh sorry didnt pick up on it, i have had some stupid offers lol, yeah anyone that know's skylines will realise its a good thing at a great price. series'3 boxes are very very rare to see for sale.
 Share
    • Remember our cars are 30+ years old so expect the rubber bits to leak. I'd go around your engine bay with a can of "start ya bastard" or similar and look for leaks. FYI I got my car 10+ years ago with the standard boost restrictor in place, I removed it when I got it and the car never had any issues since (besices a leaking manifold gasket). tl;dr- Look for leaks before proceeding.
    • That SSR is actually the same (or similar) as the Jaycar 100AMP SSR (which I use). They suggest the resistor to stop the SSR turning on when the ECU turns off (I believe). I personally don't use the resistor as I use the 5V output from the ECU to supply power to the SSR. I do however run a flyback diode, the old Haltech documentation was wrong too and didn't specify the fly back, I mentioned it to a few of their staff and they eventually added it in.
    • I did manage to do this without removing the engine or front cross member, but I had the advantage that the exhaust manifold was removed. I am not setup to support the engine from the top or remove it. 1. Loosen the engine mount nuts so they only have a nut of thread. If it is a manual, I think you have to remove the gearbox to engine support brackets. 2. Jack up the engine off the bottom idler mount. Jack it up till the end of the slot and nut on the mount. You need this clearance to get the pan out at the rear of the engine. 3.Break the sealant seal to sump. I found a oil pan separator tool helpful to get it started. 4. The oil pick up can be removed with the gap available.  5. The oil pan can be removed now. 6. Before assembling, do not apply sealant to the oil pick up area as your hand will rub it all off but apply to the other three and a bit sides. 7. It is a two man job to put the oil pan back, with the sealant, as you do not want it to touch anything and rub off. 8. With one person supporting the oil pan the other can fit the oil pickup 9. Apply the remaining sealant. This would be more difficult with the manifold or turbo in place, but I think it could be done. As you can see my sealant is a bit ugly, but good enough to seal. 10. Lift the sump up to the engine and bolt it on. We found it was easier to use two long guide bolts at each end to get it nice and aligned without touching.
    • I find building an exhaust a really satisfying job! Looks nice!   Did you consider using an oval pipe to get the same cross sectional area but keep it above the chassis rail?
    • @Dose Pipe Sutututu Sounds good.  Just double checking with the pull up resistor indicated in haltech's info sheet for their SSR - https://www.haltech.com/product/ht-030202-solid-state-relay-100-amp/  I'm guessing that would only be if the ECU did not have an internal pull up resistor? Their instructions are pretty strongly worded lol "1K pull-up resistor MUST be fitted."
