I have just started up my new motor to find it blows smoke from the turbo's due to the turbo bearing housing having to much pressure and pumping past the turbine ring. My oil return lines are a -8 going into a -14 T-Piece on the block in the stock location. HKS have a kit that does the same so the T isn't an issue.
I am however not sure if my return lines are to small and or my Reimax oil pump(huge gears) is pumping a stack more oil than std(definate). I plan on installing some .8mm restrictors into the oil banjo bolts and see how it goes. If that doesn't work I will look at my oil drain sizing. Will check my PVC aswell to make sure the crank case doesn't have to mauch pressure.
Has anyone had experience with this issue and aftermarket oil pumps?
any idea's?
pls help
Matt
Edited by BoostdR
what turbs?
mine are bush bearing (r32 N1) and have no oil restrictor - i have the same issue with my nitto oil pump.
presumably it is not such an issue with ball bearing turbos which should run an oil feed restrictor.
Turbo's are HKS GTRS (Garrett gt2860R-10)
They are ball bearing, so should have a prefitted restrictor....but that would suit the std oil pump.
Here are the specs of my pump....pumps alot more
The Reimax Oil Pump is the perfect replacement for the Achilles Heel of the RB26DETT. The OEM unit is notorious for starving tuned RB engines of oil at high RPM`s.
The Inner Rotor size has been increased from 77mm to 85mm, and the thickness of the rotor teeth has gone up from 11mm to 12mm.
The metal composition of the pump has also been changed from Sintered Alloy to SCM430H.
At 6000rpm, the Reimax High Flow Oil Pump flows 70L/min VS 47L/min from the OEM unit.
The pump's Regulator Valve opens at 7.2kg/cm2 (+/-0.3kg/cm2) of pressure, at 2000rpms, or when oil temperature hits 80 degrees Celsius.
Not only does this item boast great figures, it has also proven its build quality in Gr-A races throughout Japan.
1. That pump flows similar to an N1 oil pump
2. Those turbos aren't smoking because of the oil pump
Check your engine by doing a compression and leakdown test and then if they come up ok, check the breather system on the cam covers to ensure nothing is blocked
Well aside from the fact it's not actually oil starvation that is the achillies heel (its infact the head/restrictors, given 1ltr overfill fixes it)
You might well need inline restrictors.
Seems a few people running high volume pumps have this problem as the internal cartridge restrictors aren't enough - no idea why given plenty of others have no issues (strange)
You'd want them the same size as inline, don't wanna go any smaller.
I don't think it'll be the drain either as you've stated - its the same as what comes with the kit.
You could always just run one turbo for 1min and workout the volume approx if you are worried thats the problem
thanks for the replies. I will keep you all informed on my findings.
What size is the internal oil restrictor?
I would love for it to not be the turbo's and just my rings taking a while to seal. The motor has only been run for 10min since rebuild around the block.
Hi Elite. I know you have a stack of experience on the subject. Can you elaborate why it can't be my turbo's? I have braded oil return lines that don't go directly down also as the std do. i think the front even travels up hill for a very small time before going into the Tee as its mounted on a slant...I'll post a pick when I get home in 30min.
matt
matt
Ok yeah if you could posts some pics that would be good.
The oil pump does not flow enough to bother those turbos. So it's gotta be something like the oil drain, the breathers, or the rings. Depends on what the builder used to assemble the engine. If he used engine oil (I cry when I see this) then it will smoke for a while.
Also depends on if the engine failed before, you can have a lot of oil built up in the exhaust from a previous engine failure.
Make sure you don't run that thing at idle for any more than 1 minute. Get it on decel on hills as much as you can and hold the foot brake in 5th while climbing hills. Will bed rings in better that way. But follow your builders instructions if he has given any
He uses nulon assemble stuff...real sticky white coloured goo. No engine failure before and a new exhaust.
Just give it to me, Ill fix it. FYI you have one of my dream setups.
I dont personally see those returns being an issue. How is crank ventilation taken care of after the build? Running stock or has added breathers/catch can?
+1 comp and leakdown to proceed.
Just for another piece of info i just fitted a pair of genuine brand new hks gtss to my 26 and in the kit it came with 2 replacement banjo bolts with very small restrictors in them to replace the standard oil feed ones to the turbos. i have heard that oil flow needs to be reduced to ball bearing turbos a few times in the past as well. Sorry i cant tell you what size the restrictor was in the bolts but it was alot smaller than the one in the turbo cartridge.
Yes a comp and leakdown test are good ideas but i would be calling one of the turbo suppliers and seeing what they sayabout the restrictors first.
It has a catch can that runs inline with the stock setup. Same as with my old 26. I'm about to start testing. figures crossed.
ok. I have checked a few things.
The Oil pressure when cold is 7kg cm2
when half warm its 4.5kg cm2 (didn't want to let it idle to long)
I have found my front pipes are dripping with oil at the join in the lowest place when untightend. The comp is all good. Perfect actually. The plan is to fit some .8mm banjo restrictors in the bolt that on the side of the turbo.
Will call Enzed 2or pertek....or make my own
Move that T piece down the the fitting that goes into the block, then run the lines from 45 deg out of that in an upward direction. -8 is probably a little too small also. The factory hose is like 19mm ID so even a -10 is pushing it
I think this will be your problem.....but even a stock oil pump would have done the same. Pooling in the return line is going to push oil out
I agree with Dan, also maybe ditch the T piece and change it to a Y piece.
I can see the oil pooling and the lower part of that T piece.
I didnt seen anyone else ask the question so I will... Did you not use the factor oil supply banjo bolt in the block that is marked with an M? The factory bolt has a restrictor built into it. I think the restrictor in the banjo bolt is about 1.5mm, to restrict flow for both turbo's. See attached pic.
It would be hard work getting access to that bolt with the engine in the car already... so like you are thinking, making up restrictors for each turbo is your next best bet.
I too have heard time and time again that the GT28 cores have internal restrictors, but if they really do ive yet to actually see them actually do their job and restrict oil flow even a little. I'd put money on the fact that if you were to connect a -3 fitting to any GT28 turbo and blow 100PSI of oil pressure to the feed line it will still leak into the intake and exhaust housings.
If you went down the aftermarket/custom hose path www.atpturbo.com sell a -3 restrictor with a 0.035" restrictor hole for the GT28 cores, that bolts straight into the turbo. In the past just made my own restrictors by filling a brass -3 fitting with solder and then just drilling it. Since the solder melts at 350 degrees there is no chance it will come loose and end up in the turbo.
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
