all stock, raise the boost on the 32s rb26 and it should be a different story. cant do much with na =(
Oh buddy, theres pleanty you can do!
VQ35HR, 6 throttles with tuned length intake runners, decent mandrel bent headers, high flow exhaust, aftermarket ecu with VVT control. = 360 - 380Hp depending on quality of execution? :)
Edited by chad bob
I was actually hoping that the v35 will do better. Again the brakes seems to be fading after 3 laps just like in another clip where the v35 went against some rx8s and 350z.
Yup!... That's why I love this clip.
VQ35HR, 6 throttles with tuned length intake runners, decent mandrel bent headers, high flow exhaust, aftermarket ecu with VVT control. = 360 - 380Hp depending on quality of execution? :O
http://www.350zmod.com/Jenvey-Individual-T...tb-350z-g35.htm
Unfortunately the cost to power gains ratio is far higher than FI
if u had alot of $$$ that is. the amount spent on making an NA to 360-380hp, would be better spent to FI the car. :P
and also from what i meant was...without spending a single dollar *maybe just a manual controller* you raise the boost of the 32 it will beat the v35 with ease. with the NA you cant do much...well nothing at all really if you werent going to spend any $ on it.
What Clip?? I wanna see... post it. I always love watching our cars do battle. There isn't enough of it.
Yeah you got a point mate but seriously, you're comparing Turbo VS NA... Of course a few tweeks here & there will turn the tables for the R32...
My point was that (despite the massive head start lol) a heavy stock NA-Rear-Wheel Drive 350GT was able to beat a lighter stock 4-wheel-drive R32 GTR V spec lap for lap... which deserves a thumbs up. :P True?
If any of you guys have any more Hot Version or Best Motoring clips of our 350GTs can you point me to them... Thanks.
Yes you can get more gains from a turbo motor by just winding up the boost BUT a well tuned NA is so different and sounds so awesome!
You can't go past the sound of individual throttles at full noise and the lumpy idle with a set of high duration cams is just too nice. I also think that completing the mods that I mentioned earlier would be on a par if not cheaper than a turbo / supercharger kit.
If the track was empty I think the R32 would have done a faster lap time than the V35. He was simply stuck behind him a few times.
Tyres, drivers, condition of vehicle, etc would also play a part. The R32 is 15 years older.
In any case, slightly disappointing result for the V35. Stock vs stock vs stock i thought it would be at least a little bit closer to the other cars.
Gotta agree with Brad as I was kinda disappointed as well seeing the v35 so far behind the imprezza and lancer..... was hoping to be much closer although those are 4WD cars.
Yeah, and the TS version is like $6k, seriously why bother?
Exactly. 6k is the US price just for parts. Add the rest as well as tune and supporting parts and you've gotta be nuts to build an NA V35. Or etremely rich and don't mind losing money.
i understand where you're coming bud, nothing better then pure NA sound. but like i said what i meant was *without spending any money* all that the 32 has got to do is the boost up. na no...
individual throttles....mmmmmm :thumbsup:
    • I would hope so. I worry that it also might depend on whether the person working on the claim has had a good day or not. I could imagine that for example modified brakes would be an easy thing to point to for affecting the outcome of an accident. I don't know. I will keep paying my premium and hope for the best. But at the same time keep safe distances, drive defensively and avoid dickhead P-platers in lifted utes
    • I was just working on the assumption that a cammed V8 is significantly less polluty than a Japanese I6 turbo was at the way they tested it in an IM240. Perhaps I'm wrong! Perhaps cutting one of the readings I got in half is a tall order. I don't know too many people who actually got their cars emission tested with a RB to really compare the data.
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
