The Car Always Going To A Side When Hands Not On The Wheel?
Get a 6 boost manifold, a Garrett or precision turbo that will make the power you want, call some like mobile custom fabrication that can come to your house and do good fab for you. Get a bigger fuel pump and injectors and a modern ecu like haltech or link. Then the car to be tuned at a shop with a good reputation, I use just engine management in ingleburn
Possibly an old turbo timer.
Yeah very fair, and still relatively untested on RBs - though initial results from the RB30 ECR33 in Brisbane look pretty impressive. G40 looks like it should be a pretty solid choice, a few people have used them too.
The specific reasons I suggested them in this case are: * OP has a complex issue that needs to be checked out thoroughly, so their engineering approach rather than just chuck whatever on should help * I've found them to be honest about what problems exist, even if the customer doesn't want to know bad news I'm sure there are places that will bolt on stuff and do a tune cheaper, and faster
Its definitely not factory. You'd have to check but the yellow wire is something in the key (so see when it has 12v). The blue wire would have been a switched version of whatever the yellow wire was (eg if yellow is IGN, then blue was something that can be switched on when IGN is on). Whatever it is, it is now inop if nothing is plugged into it.
