my housemate's r34 got a problem cause the car not going straight when hands off, it's going to the left.
he brought the car with this problem since 2 years ago.
he changed all new tyres and suspensions, and did a 4 wheels alignment recently, but the problem still don't go away.
the car should not been crashed and don't have any damage on the body.
anyone has any idea what's causing this problem and how to get rid of it?
cheers,
ryan
I had a problem with this when i first got my car also until i took it to my mate to align it...
the issue will be the car is aligned straight so the road camber will be throwing it to the left, what you need is some one that knows what their doing to put a slight toe-in on the front left wheel to make it drive straight.
+1 ^
Wait Brad is leaving!? :)
To the OP, could be any number of problems, my mates R32 had the wheels aligned twice by two different places, turns out it needs a camber arm kit. My car used to do it, found the front left tyre was 3psi flatter than the rest of the tyres, pumped it up and problem fixed. Although it still does it on the freeway which leads me to believe it is the camber of the road causing it.
Do you have a previous wheel alignment print out??
If you do, get it in your hand and give me a call as there is some info on it im curious about.
(WA Suspensions 9444 0500)
Also, castor rod bushes...have they been changed or are they still standard hydraulic ones?
Camber of the road can and will affect it aswell. No one will ever make the car drive dead straight as our roads are cambered....but it can be made 'better'.
What tyres are on the car? is it a known 'decent' brand? (Bridgestone, dunlop, sumitomo, etc etc) or a cheap china brand like LingLong, Wanli, Triangle?
Just becuase there is no damage to the body does not mean the car has not gone over a kerb at a fair speed. Just for shits and giggles, measure the wheel base left and right (centre of rim to centre of rim)....whats th difference in measurement? 5-10mm can make a differnce.
Roads have camber ? :)
Yerp, very important factor in road design.
Taken from http://www.arrivealive.vic.gov.au/initiati...rovements.html:
"The camber or tilt of a road can greatly influence a car’s ability to travel safely through a curve. A poor road camber increases the risks of vehicles running off the road. The road’s camber will be improved at locations where it is associated with a high number of fatality or serious injury crashes."
*EDIT* Also what Brad said about water drainage etc.
Edited by Hanaldo
thanks everyone.
the tyre pressures is good, and they are continental, so shouldn't because of the tyres i think.
i know the road got camber, but even it drive on a really flat surface that every car can go straight, it just can't. :)
he did a 4 wheels alignment 3 weeks ago at WESTATE AUTOBAHN in Newcastle Street, Perth.
we droped the car there and 3 hours later they call my friend siad the car is ready to pick up and it is all good. they didn't point out any thing at all...and the car still going to the left...
castor rod bushes haven't been changed. they can be contributed to this problem as well?
cheers,
ryan
I took my car to Peddars when I first got it for an alignment and 28 point safety inspection, they got all freaked out and flustered working on an import, told me my whole rear suspension setup was f**ked, would need to replace the whole thing, they quoted me $5000 ffs.
Took it to WA Suspension for a second opinion, Brad called me back after about an hour and said it's really not that bad, there was some slight play in the rear sub-frame bushes that could be fixed with some pineapple bushes. Got the work done, ended up costing me about $560 all up.
Seriously, take it somewhere where they know what they are doing (read: WA Suspension).
+1 for WA suspenders.
Had them knock up an alignment for Teh Fury yesterday, and was forced to stop twice on the way to home so I could get out and roll naked across the bonnet. I dont think the chick at the drive through coffee place will ever serve me again though :P
Hmm, turns out that there wasn't enough castor on the left front wheel so we chucked in some castor bushes and she is all sweet, $200 later problem is solved :) if anyone else is having a similar issue feel free to give us a call :(
Dale i got to drive Teh Fury back from Allans CV's, man it was terrible to drive, pulled left like a bitch, all good now though?
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
