kidafa Posted July 21, 2010 Share Posted July 21, 2010 Hi All, Im currently doing a manual conversion to my Stagea (1997 series 1). I have a few questions regarding wiring in the gearbox so the reverse lights work and if I need to wire up the neutral switch or not.. Ive done some re-search and this is what I've found: 1. In that photo when he says dont hook up neutral switch to auto ecu does he mean dont run a wire to the ecu from box or what? Does he mean dont do this if your using stock computer? In a different thread some one also suggests this: ""Go back to the front of car with the four plugs. The two pin grey plug is your inhibitor switch, put a loop between those (cut plug off auto trans loom). The brown plug is for the reverse lights (well two pins of it anyway), hook those up."" 2. So one person here suggests to use the brown plug and one doesn't... Thoughts? This is a photo of a R32 GTR gearbox (not mine but I will be using one) 3. There are two plugs on it one is black (towards front) one is bluey green (towards rear). Both are two wires of same colour. Which one is the reverse switch and which one is the neutral switch? Im guessing the black is neutral and the bluey green is reverse? At the moment Im thinking it should be like this: Use wiring diagram and supply 12v to one wire on the bluey green plug and the reverse wire to the other wire on that plug Not connect up the neutral switch/2nd (black plug) Hows that sound? All help much appreciate, Chris Link to comment https://www.sau.com.au/forums/topic/329864-manual-conversion-g-box-wiring/ Share on other sites More sharing options...
