Hey guys and girls... Thought I would put my car up in here :O
Also looking for some sponsorship if any one is keen or could point me in the right direction :)
Cheers
Kate
Engine:
2JZ-GTE
Modifications:
2JZ-GTE
GT3540 .63 housing
6 Boost Manifold
48mm TurboSmart Progate
Custom Oil feed with inline Filter
Oil Cooler kit
20psi low oil pressure buzzer
New Water Pump / Timing belt / Seals
3 Inch custom Exhaust
Braided Brake lines
Braided Clutch line
Rebuilt shorter clutch master
Custom Sleeved Clutch Slave
KTS Camber Arms
KTS Caster Rods
16mm Supernow Rack Spacer
Ikeya Formula Tie rods
Custom Tie Rod ends
Custom front Uprights
Modified Knuckles
Modified Cross member
SuperPro Rack Bushes
GTR Rear Sway bar
SuperPro Sway bar bushes
Alloy cradle spacers
SuperPro Pineapples
Custom Single Piece Tail Shaft
Tilton Hydraulic Hand Brake (Twin hand brake setup)
Tilton Brake Bias controller
Tein coil overs
4 Inch Pod
Greddy Profec B Spec II
Custom Cooler Piping
Hks SSQV Bov
Toyota 1ZZFE Coils
680cc Injectors
BMI Billet Fuel Rail
Aeromotive Fuel Reg
Custom 2L Surge tank with baffle (Fabrication 81)
Bosch 019 Intank pump
Bosch 044 External pump
9.5mm Fuel lines
Adaptronic ECU
Adaptronic Vidi Gauge
7" LCD Screen for gauge outputs
Modified Throttle Body
FMIC
NISMO 2 way
OS Gekin Triple Plate Clutch
R154 Gearbox with Remote Shifter
Koyo Triple Pass Radiator
Hicas Lock bar
17" BBS 8"/9" Rims
Bride Fixed Back
GTR Front bar
GTR Rear wing
Tuned by PITS
414hp on 14psi
https://www.sau.com.au/forums/topic/329891-kates-drift-r32-skyline/
few more pics of the build... unfortunately we didnt get many build pics which was a shame. we were pretty much stuck into it from start to finish... took about 3 weeks to complete. Pretty happy that i nailed the wiring first go... alternator light and everything works like factory apart from the speedo and tacho but the adaptronic looks after that. Was a little confused when it came to the wiper motor wiring as it seemed to be part of the stock rb20 loom but winged it haha
yeh i fabbed the engine mounts and gb mount
ive done the heat sheilding but still find that after a few track days the clutch fluid goes to shit
it has some tilton race fluid in there atm but thats already starting to show signs.... we did the conversion almost a year ago and have only had to change the fluid twice so its not that bad i guess
the pedal feel is alot better in the clutch since we had the slave resleeved to a different diametre
u know the clutch fluid is on teh way out cause the noisy tripple plate rattle gets less distinctive haha
Thanks babe you have all my pics yes i regret not getting more build pics but it was a short turn around kinda sold my forged Rb20 and started to build a Forged Rb30 and Skidman didnt wanna drift any more so we decided to swap stuff and put the 2Jz in the R32...
Good motor just that Tilton fluid can be a tad funky at times you either have clutch or not so im guessing this will be something we will be looking into as I would like to do tracks like standthorpe and Raleigh and QR is my main track and stuff gets a tad to hot to easily :bunny:
Kate scored another first place in the street class on the weekend at King of Drift... good weekend over all and no breakages... of to Stanthorpe this weekend
New video from sunday and a few pics
http://www.youtube.com/watch?v=w0WxshmBSCY
and a pic that we got from the event before at parklands
Edited by SkiDMaN
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
