Hey guys and girls... Thought I would put my car up in here :O
Also looking for some sponsorship if any one is keen or could point me in the right direction :)
Cheers
Kate
Engine:
2JZ-GTE
Modifications:
2JZ-GTE
GT3540 .63 housing
6 Boost Manifold
48mm TurboSmart Progate
Custom Oil feed with inline Filter
Oil Cooler kit
20psi low oil pressure buzzer
New Water Pump / Timing belt / Seals
3 Inch custom Exhaust
Braided Brake lines
Braided Clutch line
Rebuilt shorter clutch master
Custom Sleeved Clutch Slave
KTS Camber Arms
KTS Caster Rods
16mm Supernow Rack Spacer
Ikeya Formula Tie rods
Custom Tie Rod ends
Custom front Uprights
Modified Knuckles
Modified Cross member
SuperPro Rack Bushes
GTR Rear Sway bar
SuperPro Sway bar bushes
Alloy cradle spacers
SuperPro Pineapples
Custom Single Piece Tail Shaft
Tilton Hydraulic Hand Brake (Twin hand brake setup)
Tilton Brake Bias controller
Tein coil overs
4 Inch Pod
Greddy Profec B Spec II
Custom Cooler Piping
Hks SSQV Bov
Toyota 1ZZFE Coils
680cc Injectors
BMI Billet Fuel Rail
Aeromotive Fuel Reg
Custom 2L Surge tank with baffle (Fabrication 81)
Bosch 019 Intank pump
Bosch 044 External pump
9.5mm Fuel lines
Adaptronic ECU
Adaptronic Vidi Gauge
7" LCD Screen for gauge outputs
Modified Throttle Body
FMIC
NISMO 2 way
OS Gekin Triple Plate Clutch
R154 Gearbox with Remote Shifter
Koyo Triple Pass Radiator
Hicas Lock bar
17" BBS 8"/9" Rims
Bride Fixed Back
GTR Front bar
GTR Rear wing
Tuned by PITS
414hp on 14psi
https://www.sau.com.au/forums/topic/329891-kates-drift-r32-skyline/
few more pics of the build... unfortunately we didnt get many build pics which was a shame. we were pretty much stuck into it from start to finish... took about 3 weeks to complete. Pretty happy that i nailed the wiring first go... alternator light and everything works like factory apart from the speedo and tacho but the adaptronic looks after that. Was a little confused when it came to the wiper motor wiring as it seemed to be part of the stock rb20 loom but winged it haha
yeh i fabbed the engine mounts and gb mount
ive done the heat sheilding but still find that after a few track days the clutch fluid goes to shit
it has some tilton race fluid in there atm but thats already starting to show signs.... we did the conversion almost a year ago and have only had to change the fluid twice so its not that bad i guess
the pedal feel is alot better in the clutch since we had the slave resleeved to a different diametre
u know the clutch fluid is on teh way out cause the noisy tripple plate rattle gets less distinctive haha
Thanks babe you have all my pics yes i regret not getting more build pics but it was a short turn around kinda sold my forged Rb20 and started to build a Forged Rb30 and Skidman didnt wanna drift any more so we decided to swap stuff and put the 2Jz in the R32...
Good motor just that Tilton fluid can be a tad funky at times you either have clutch or not so im guessing this will be something we will be looking into as I would like to do tracks like standthorpe and Raleigh and QR is my main track and stuff gets a tad to hot to easily :bunny:
Kate scored another first place in the street class on the weekend at King of Drift... good weekend over all and no breakages... of to Stanthorpe this weekend
New video from sunday and a few pics
http://www.youtube.com/watch?v=w0WxshmBSCY
and a pic that we got from the event before at parklands
Edited by SkiDMaN
    • Hi all. So I have my GTR on the lift and have been working on it a few days and yesterday I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
