  • 3 months later...
bit of a thread revival... thought id give it a update... car has been running great past few months.. kate landed herself another trophy over the past weekend at another raceline event here on the gold coast...
got a little bit of footage from a queensland raceway morning session we attended about 2 weeks ago... got about 2 hours in before the bracket for the power steering decided to break away from the block... previously the engine was from a car that was in a bad front ender which broke the ps pump of the block and cracked a few things here and there... the weld has lasted for a good year so wasnt too phased about the breakage. Went straight from the track to our fabricator and fixed that same day and drove home!
ne ways... on with some pics and vids
Kates day at parklands
QR drifting... first 2 runs is me and rest is kate driving
Edited by SkiDMaN
  • 5 weeks later...
well the power steering bracket keeps breaking of the block
electric power steering here we come
have had a bracket made up to make the alternator adjustable to do away with the auto tensioner as it cant be run when the engine has no ps or air con the way its designed
will have it up and running this weekend and have a full track day out at queensland raceway on monday to test it and refine it then have the last raceline comp on boxing day... going to be a busy week between xmas and all that stuff!
heres a pic of how the pump sits... we actually did a whole drift day without it chewing or throwing the belt... then drove it 1 hour home haha... was rubbing on the auto tensioner pulley the whole time!
Edited by SkiDMaN
  • 9 months later...
well the elec power steering didnt work the way we wanted it too... we ended up milling 5mm of the block and welding in a 5mm plate but under high load it was still spitting the belt.... she sold her dirt bike to fund a new engine.... we decided to take it to one last event that she really wanted to do even if it was throwing a belt every now and then... she ended up winning her class but it was a very busy day in the pits!! the belt let go about 5-6 times throughout the day haha
got it back home and let it rest for a week till i could take it to a mates workshop to pull it down.... while the engine was out we decided to get the engine bay resprayed as its had 3 different rb20's put into it and its had its fair share of oil and scratches
as it sits now we have just slotted the new motor back in and it should be up and running within a few days and ready for a few events over summer... will be good to get back out there!
we have both been drifting on and off for the last 3 years or so
have only done 2 events this year... hoping to do as many as we can before the year is over... the car never over heats no matter what the weather is like which is good... only prob we have is the clutch fluid turning to water after a few track days in the summer time... have had to rebuild the clutch master once already... the heat kills it pretty quick... have also replaced a booster.... it does get a fair whack of street driving though so servicing those items every 6-8 months isnt that bad
  • 10 months later...
Far out didnt notice how long I havent been on here for so heres some pics for you all.. New motor has gone in after we couldnt get the bracket to stay on and changed my ECU to a mircotech..
Came 4th at the PM lubicants round 5 at Archerfeild on Sunday was Stoked =]
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
