valid points. although i still undecided in terms of al vs ss lol
ahhh what to do what to do. !!!
i have to try and get the 2 sets of twins happening. theres a pic of a m35 on speedhunters with 2 twins! there must be a way. probably some stupid setup lol like the crx's you see with "twin exhausts" and when its cold only 1 zaust has condensation coming from it ahhaha
245 thats f**kin awesome power!
Also remember this is the RE dyno, well known to read 20 - 25kw under. I don't want to find the limit of the rods just yet. :)
Anyone know of another 4 wheel dyno around south east Melb?
Geez nice work scotty!! thats a great number. hows the transmission feeling?
no, its probably a RWD model and there is room for the rear can and all the piping down the other side of the tailshaft and transmission.
I just got back from RE, the turbo is definitely maxed now as the compressor cant supply enough air. He gained a heap of response by leaning the acceleration enrichment as it was dumping too much fuel.
Its very nice to drive now and even Cihan commented how well sorted it feels. He suggested a gt3076 .82 would be a better match for the mods and engine as it stands, im not sure the internals can handle the 340 odd it would then produce though.
show off :D
like the curve BTW!
I'll put mine on a Dyno as soon as I get it back on the road......lets see how much I can close the gap :D
Edited by Jetwreck
show off :D
like the curve BTW!
Boys and there toys! The AR-X is always going to have slight disadvantage :)
The dyno runs were done with the torque converter locked, the gearbox ran smooth and changes are perfect. When Cihan got on the gas too fast it would kick down to third and spin the semi's on the rollers.
With the converter unlocked on the street it has instant boost which makes launching in first very snappy. Its quite refined to drive still and I have no problem letting the missus take it but it definitely spins up all 4 in the wet now.
Considering the small size rear on the turbo it's doing quite well I think.
+1. As usual, impressed by your pioneering innovation! You must be extremely pleased with the results, with 245 conservative AWKW's, your car must be quite a beast now. I can only dream of achieving something close. Nice to know it's possible. Champion effort!
I can tell you it was quite enjoyable to drive before this tune, can't wait to take it out now :P
As I said last night Scott, absolutely awesome result... can't help but think that perhaps you feel that your real power struggle is with those stroked VQ25det M35's in Japan.
So what are you doing with that GT35/40? :D
I can tell you it was quite enjoyable to drive before this tune, can't wait to take it out now :D
So what are you doing with that GT35/40? :)
The core is stuffed, I was just going to use it to test fit for the gt30, or should I... ;)
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
