hi guys, first things first, i have a psi guage, actualy in psi, and its the second one ive tried, and they both say psi.
now
my solonoid is out of the question, nothing runs to it at all nor is it plugged in, and i have the hose running straight to the actuator, im only getting 5 psi, i thought it might have been a leak in the system, but its a solid 5psi and dosent budge up or down when full throttling, if there was a leak the boost would drop slowly? or something
anyway, any ideas?
cheers
  • Replies 74
Standard turbo?
If so then yes, about 5psi is all you will get running straight off the actuator.
yea standard, i thought the actuator is 10 psi?
do i have to hook the solonoid back up to get 7-8psi?
alright so im gonna have to hook it back up and then, do the DIY for high boost all the time correct?
Could just buy an rb20 r32 actuator?
getting a little hard to find these days, I Think I have one in storage lol
i dont really want to run 10psi, im not into the whole "must go faster" thing anymore, just would like the standard boost! 10psi = screwy mixtures etc since i just have the standard ecu
No you just have to reconnect the bleed line to the bov return pipe and play with the diameter of the restrictor until you get the desired boost - bigger diameter = more boost. If you have lost the restrictor you can just solder up that branch of the T and drill the hole progressively bigger till you get the desired result.
Get a $30 tap and set it to 0.7 bar (8psi) yourself like I did. Better than stock IMO, more torque down low (obviously) and spools a little sooner.
The turbotech one on ebay is the one I have, well documented on this forum as to how good they are.
GL
GL
if im not mistaken, the taps are quite unreliable, ive used them in the past and they cause boost creep issues...
to be clear
standard R33 GTST auto is 5psi
standard R33 GTST manual is 7psi
both have a boost scramble or "boost hi mode" which bleeds in another 2psi around 4500rpm from the standard solenoid
if you bypass the standard solenoid and do nothing else minimum boost for auto is 5psi and manual is 7psi
to be clear
my car is manual and its 5psi, hosed to the actuator
maybe your turbocharger failed and yours has been replaced with an auto turbocharger?
maybe your actuator has failed and your actuator has been replaced with an auto actuator?
maybe your car was auto and converted to manual?
unlikely but possible
