Massive Clean Out
Guys Im cleaning out my Garage's
So offloading all the un-needed bits cheap
Item #1 - R33 RB25DET Block, Needs a Rebore, comes with Girdle, but no bolts or accesories - $50 pick up only from South Canberra.
Item #2 - Rb25DET Crank Shaft Standard size journels, micro polished - $100 pick up only
Item #3 - Rb25DET Crank, Needs grinding, already done 10thou on mains and 25thou on Rod journals - $40 Pick up
Item #4 used Stainless High mount t3 manifold, used for a few months, suit 38mm 2 bolt Tial Gate, No cracks - $75 + post
#5 - 38mm Tial Copy gate used for a few months $50 plus post
#6 - RB25det factory Upper Plenum, No throttle body or gasket - $40 plus post
#7 - Standard AFM, Still works but a bit sad looking, good for a spare - $20 plus post.
There is heaps more to come
Ill get photos ASAP
Best to contact me via PM or reply here.
Thanks
Andrew
Just thought of some more,
3" Mild Steel Cat Back Exhaust Suits R33 2 Door, Single Oval Muffler at the rear, Ok Condition, Cat is welded to the pipe, but the insides have fallen out, The muffler is around 18 -24 months old, the rest is around 4-5years. - $50, please note the exhaust is in Goulburn NSW would prefer pick up from there.
Used Rb30 Oil Pump, No idea on condition, came out of an RB25/30 which munched the bearings - $20 plus post
5 Rb25det factory Conrods and 6 ACL Race series Forged Pistons, The 5 rods are usable and 3 maybe 4 pistons are. Pistons are 86.5mm and 8.5:1 Comp. - $50 for the lot
Turbo Smart Boost Tee - Not very old, Came with the Soarer I bought - $50 posted.
 Share
