That's right, it may have 192000 KM, it might need a new bodykit and A/C compressor but it works and still puts out 229rwkw.
Silver 1995 R33 GTS-T auto
192000 KMs
PowerFC + HC tuned at Racepace
Tomei 720cc injectors
Walbro 255lph fuel pump
FMIC
'Slide' rebuild turbo at 16psi
ProfecB spec-II
Titanium cat-back (really titanium not coloured SS)
18" el cheapo starcorp rims 235 front 265 rear.
Waterpump recently replaced and radiator end tank replaced (hairline cracks showed under pressure).
450k to a tank.
No sound system. At least not working, I took the amp and sub out.
Front bar needs to be replaced/repaired. Driving it with it held on by zip-ties
Rear bar needs respray.
Needs new A/C compressor for cold air. Whole system was replaced 18 months ago, only the compressor was reco :P
Rego runs out next month.
Original ECU, injectors, fuel pump all included. Unused slotted rotors and Tomei head gasket as a bonus. Rebuilt C4 with bellhousing to suit available for $1k more, picked it up to replace the stock box if it died, never did, it's the Kieth Richards of gearboxes.
$4000, come get some. Available for inspection in Mulgrave during business hours. Want it gone to get a new car because I don't want 3. Sold as is, roadworthy and reg up to you but with the parts available that's not hard.
https://www.sau.com.au/forums/topic/329923-holy-flaming-testicles-of-christ/
It might need dust caps on the suspension and a couple of bushes. I'll help out with any suspension / undercar parts etc for the buyer because I can get them at good prices through a client.
It's a silver R33, I don't have any current pics right now but I can get some tomorrow.
Also has:
Z32 AFM
Generic adj strut brace
Sedan headlights too, the chrome/silver type instead of black. Old ones were getting too 'foggy'
I have a S2 s/wheel to replace the ratty S1 but the airbags are not the same - different placement of the controller unit so it would have to remain disconnected.
Edited by DivHunter
    • I don't know why we've had a different experience, but I've had them on the race car for 18 years and not a drop, and have them on the stagea too, same, no problems.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
