Okay, so for a while I've loved the Nissan Cube. I know for some of you it'll be a love hate car, but for me it's all love :(
I wanted it from the minute I laid eyes on one on my first trip to Japan. After compliance became available for them last year, I'd been looking on and off. Then I saw some local examples, and I knew I had to have one. I've been looking every day for the last 2 months for one that suits my needs, bid on many auctions, checked out many dealer cars but for a number of reasons the sales fell through.
Then this evening, meet my 2005 Pearl White Nissan Cube Cubic 15M purchased at auction.
1.5L 7-seater and the late model version or series 2 if you like. Absolutely immaculate example with 49,000 legitimate km's on it. Black interior. Grade 4.5 condition with not a single dent and the tiniest little fingernail or less sized marks on both bumpers. No accident history. Absolutely beautiful condition.
A bit of background, the 1.5L shares the same engine and driveline as the Tiida. The 1.4L, the Micra. It's a small car with the most amazing amount of space. It seats 7 adults, and with the rear two rows of seats folded down it fits a Nissan option double matress (no I'm not buying one :)) They also came in 5 seater versions. The Cube is a 5 seater, the Cube Cubic (otherwise known as a Cube3) is a 7 seater. They were the biggest selling small car in Japan with good reason - tonnes of space, quirky looks and character and more factory options than any car in the history of the universe, tiny turning circle and excellent fuel economy.
I have a few plans for her, nothing outrageous. Custom plates were ordered tonight; 'CUBE.3'. She hits our shores in the next couple of months, more pictures then too.
Here's what I intend the car to look like later on:
I spent a bit over my budget to pick up this example so unfortunately it won't happen overnight, but it will happen. The overfenders and stickers are factory, called the 'Neoclassical Aero Package'. They're pretty expensive new from Nissan.
As Big Kev would have said (rest his soul), I'm excited! ;)
https://www.sau.com.au/forums/topic/329992-my-new-daily-driver-cube-cubic/
  • Replies 107
Yup, 7 seater, though I plan to have the third row of seats folded down most of the time (they folder flat and the headrests store in side compartments.) With the second and third row of seats folded down the storage capacity is massive. There are storage compartments in the seat cushions as well.
Floorplan:
saw one last night @ importers place he said 15K landed (could be base model not sure)
This cost more than that. But this is a S2, 1.5L, almost flawless condition with 49,000km's so it was worth the extra money. Most of the Cubes/Cubics you see currently in Australia are very bottom of the barrel base models tarted up to suck people into buying them. Importing is still the better/cheaper option. Plus importing is more fun :)
Ideally I was looking for one with the Neoclassical Aero Package but there are barely any Cubic's with the kit (mainly Cubes) and I wanted pearl white, which narrowed down my chances to nearly zero. This is a good base to start from :D
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
