  • Replies 107
Spent a silly amount of money getting all 7 seats and the headlining steam-cleaned, but it was definitely worth it. Interior came up much better with a professional detail. Also, some more quick photos. Needs photoshop coilovers hehe
I'm still loving the fuel economy.
No mods to report. New centre console lid latch arrived, so I put that on today. Unfortunately didn't match my trim colour but it's not like you see it with the lid closed anyway. So now I have a functioning centre console.
And chucked on my JDMST sticker. The Skyline feeling lonely in the reflection. I drove the Skyline for the first time since I got the Cube today. Feels like I'm sitting on the ground compared to the Cube. Gone are the awesome viewing angles, comfy suspension and light steering.
  • 4 weeks later...
The Cube's come with a massive, obnoxious aerial which makes it impossible to go under tree's, into carparks, etc. I installed a much smaller aerial today. It was listed as being for a 350Z but came with universal adapters. It also hasn't affected reception at all.
Before:
After:
  • 3 weeks later...
Ordered:
*Genuine Neoclassical Kit
*Genuine CUBE3 Side Stickers
*Genuine Bonnet Sticker
*Genuine Cargo Net
It was always my intention to have the neoclassical overfender & sticker kit on the car, I just had to wait until I had enough money because it's not cheap buying brand new genuine Nissan. But god it'll look great once it's on. At the same time I'll get the little ding that came with the car on the rear bumper fixed and resprayed. Happy :D
  • 4 weeks later...
My kit and stickers arrived last week but I have a mental dilemma. I'll be respraying the rear bumper to get rid of a dent that it came with from Japan, and at the same time this will take care of the colour-matching issue the bumper currently has (that is a normal thing being that the paint on the plastic ages differently to the paint on the metal over time and pearl white is the worst colour for showing this.) Now obviously the paint on the front bumper has done exactly the same thing. I'm thinking if I go to all the trouble of doing the rear and then not doing the front I'll keep looking at it, knowing it doesn't match and regretting it. Arggggh, I hate feeling the need to repair something that isn't broken.
Looks like I'll save up to get both bumpers resprayed and the kit and stickers fitted professionally. I know the kit and stickers are something that I could do myself, but I'm always scared of screwing up things on the body. Maybe best to leave it to a professional?
    • Por que no los dos? At least my euro brawler is reliable - unlike the JDMs I've had. Sheraaz you look familiar, did you ever come to an SAU VIC meet aaaaaages ago?
    • Drove to Cape Schanck to try to get a nice clear southern view over the ocean to see the lights a couple of days ago... instead got crappy cloud cover. Photo of a diorama of Hong Kong street scene. Taken on an iPhone 13 Pro Max.
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
