hey guys just purchased a r34gtt about a month ago and have noticed some problems..
i have read throught other forums about this problem but wanted to get my own advice..
i was driving with TCS off n noticed the SLIP light started flashing as well as the HICAS light..
the car has done this twice now the first time the car stalled and wouldnt start for about 10mins..it seemed to me as if the after market imobiliser was the problem so i got it taken out..now the car did the same thing but didnt stall..i noticed after this happened the TCS and SLIP stayed on while i was driving..but when i turned car off n on it went away..(but still from what i have read the slip light shouldnt come on at all while TCS is off).
any help would be great..
the car also has power fc and a nismo 1.5 lsd...if these could be causing it.
https://www.sau.com.au/forums/topic/330004-hicastcsslip/
my r34 gtt is an auto and i have tcs slip and engine light comming on (only every now and then) could be related . had it scaned buy nissan (stock ecu) at this stage looks like TPS sensor #2 don't know if a manual has this sensor but it make my car run like crap. gets fix on friday will let you know if its fixed.
Edited by AZZA R34
https://www.sau.com.au/forums/topic/330004-hicastcsslip/#findComment-5368939
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
