Email: [email protected]
Mob: 0431 048 154
ANY REASONABLE OFFER WILL BE CONSIDERED NOTHING BELOW 18.5K PLEASE DONT BE STUPID NO SWAPS EITHER
ALL STOCK STANDARD PARTS KEPT. AND WILL BE SOLD WITH CAR !
-MODS-
*please note all price are what i actually payed for them at the time they don't including tuning or installation
-Apexi Power FC with Hand Controller $2500 + tuning at Chasers Motorsport
-Hi-Flo Turbo - Built by Kyp from ATP for 300RWKW $900
-Nismo R Tune Suspension imported from Japan wasn't available in Australia at the time when i purchased it $3300
-G-Reddy E01 Boost Controller with Hand controller & screen $1300 from Autobahn + tuned at Chasers Motorsport
-Nismo Fuel Regulator $250.00 from Japan
-Bosch Fuel Pump 044 $350.00 from sliding performance
-HKS full 3Inch Dump with 5 inch exhaust $1800 from Japan
-Bosch Z32 AFM
-Apexi RSM with G-Sensor $470
-HKS Sequential Blow off Valve $390.00
-Spitfire Coilpacks from $550 slidingperformance
-Custom Made V Mount Intercooler
-ROH Deep dish Wheels (cannot find these anymore $3000) Rear 18x9 front 18x8
-Silver Carbon fibre Bonnet With 3 Air Vents $1200
The car is always serviced by myself and i always used Motul and Redline oils NGK Sparkplugs. Gearbox and Diff have both been serviced.
I would love to keep this car but i am getting married and Buying a house so i need all the money for a home loan, the prices for these cars have dropped dramatically on the market but my price is pretty firm you could find other cars for cheaper than mine but i can assure you that they wont be taken car for as i have mine. currently the car makes 245RWKW on 16PSI but i daily drive the car on 12PSI
Mob: 0431 048 154
ANY TEST WELCOME, AS I NEED TO SELL THIS ASAP. PLEASE DO NOT WASTE MY TIME AS I HAVE NO TIME AS IT IS.
PRICE IS NEG !!!!!!! NEED IT GONE !
Edited by Tushar
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
