Any pointers?
I've jump started it from all sorts of things from GTi-R to a tow truck with twin batteries it still wouldn't start. In fact I've melted 2 jump start cable..
It just crank slowly, crank again then crank again till the cable melts...but funny enough it did start last weekend. Any ideas? It seems like there's not enough power to the starter to crank it into life. Funny enough the power windows refused to work as well.
https://www.sau.com.au/forums/topic/33004-r33-wouldnt-start/
it might help if u have fuel in the car:D possibilities are starter motor?? did u play with the fuses?? i played with the fuses last time in my car and put one in the wrong place and it wouldnt jump start at all...it would crank over and then die. have u tried putting another battery in your car to see if its the battery at fault?
i dunno....good lucks with it
https://www.sau.com.au/forums/topic/33004-r33-wouldnt-start/#findComment-662476
There's fuel but doesn't seem like a whole lot in there. Possibly drop another 5L in there and see how it goes...
Which fuse(s) should I check?
With batteries..haven't tried that but the battery shouldn't matter - at least with my other cars even if the battery's screwed, I can still jump start it just that it can't be charged.
https://www.sau.com.au/forums/topic/33004-r33-wouldnt-start/#findComment-662538
coils not producing spark? spark plugs stuffed? I would say if you have cranked this car till the jumper cables have melted you would have done some serious damage to the starter, as it is only ment to run for 5 secs or so. Also, Im with Chucky, make sure your engine is properly earthed to the chassis, because a bad earth connection can make wires heat up and melt, especially when your using lots of amps when cranking.
https://www.sau.com.au/forums/topic/33004-r33-wouldnt-start/#findComment-664129
And if your +ve wire or -ve has melted that would explain the slow cranking short of a stuffed starter...
Sumo
P.S. Sometimes its easier to just take it to a autoelec and they should if they are decent give you a heads up on what is going on, free of charge. I know at my work we do.
https://www.sau.com.au/forums/topic/33004-r33-wouldnt-start/#findComment-664166
My experience has been that when the battery has totally died, and you need to jump start it, you need to have the 'jumper' connected to the 'jumpee' and engine idling for several minutes. The 'jumpee' battery needs at least some charge in it.
Also, the ECU needs something like 7V to activate itself. Cranking on a low battery will reduce the voltage available to the ECU to below the threshhold, and so the ECU will not activate, and if it isn't activated, it can't tell the coils to fire.
And don't forget, most cars have the battery up front, so there's not that much cable between the battery and the starter. The 33 has to get volts all the way up to the front from the boot.
If you can, connect the+ve jumper cable directly to the +ve of the starter motor, and the -ve directly to the engine block.
Alternatively, go and buy a new battery, and you'll avoid the "melted starter cables" syndrome.
https://www.sau.com.au/forums/topic/33004-r33-wouldnt-start/#findComment-665084
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
