Well, having been scared away by prices of local semis....what is a decent track tire out of the US?
If you had to chose between
Kuhmo Ecsta V700
Kuhmo Victo Racer V700
Kuhmo Ecsta V710 (not sure i can drive on the streets with these bad boys?)
Hankook Ventus Z214
Hankook Ventus TD Z221 (they are not listed on their website but askign about availability along with A050)
https://www.sau.com.au/forums/topic/330062-track-tires-from-tyre-rack/
  • Replies 47
I havent used any of the other listed rubbers, but this is what I can say about the Ecsta's.
Have been involved with production car series for a bit now and never had any problems with them.
We ran a commo R8 on 2 sets for the recent 6hour at Sydney and they held up well. The drivers did bitch a little about them going off, but when your hauling a fat pig like an R8 on rubber that you qualified with, you expect a little fading after a couple of hours of racing.
They are a little suceptible to punctures on the saw toothed ripple strips on the inside of the tyre from what I have noticed.
Be warey of of pressures too. They blister quite easily too.
This is from what i have found through my experinces on a different car and set up to yours.
the kumho stuff is good, only about 1sec slower than dz03g/re55s. V70A is the current model but they still sell v700 in some sizes.
one big "thumbs up" for the kumho, they work well (best even) after the tread is gone (ie at and past the wear limiters). the serious guys buff them down to the wear limiters straight away, but I don't think it's worth the trouble on my budget.
the kumhos also want unusually high pressure. I run 42-44psi, the commodores run right up to 50psi for best performance. Yes that is crazy, and they got blow outs on the low profile type (35 and lower) at that pressure. but man they worked well.
haven't tried the hankook although they got good results at B24 and EC12 hours.
Kumho are a good price/performance mix, as are the toyos. If you need the fastest tyres you need to pay up for dunlops.
So Dunlops are quicker then AO50? It was hard to tell as i was not at Superlap, but surely if there was a time advantage to be running the Dunlops then people not tied up/associated with Advan would have run them.
The impression i got was the Sierra Sierra Evo were the odd ones out running Hankook whilst every other person ran the AO50s?
If i can confirm what the fastest tyre is i will grab a set as i wont be getting another chance to punch out a time for suite some time...so want to arm myself with the best tyres possible.
If i cant establish that then i think the Kuhmos for $1k sound like the best option. Who in NSW sells them? May not have to get them from the US!??!
re the yoko a050 being faster....I should have said I was talking about race use.
A050 only come in a medium compound (or super soft as used at superlap), not a hard, so they are not an option unless you can afford a set every track day.
full on super sprinting/superlap/whatever is a different story. soft tyres of any brand will outperform sensible/hard tyres from any other brand. eg I ran kumho wets once years ago and took the old blue gtst into the 1.10s at wakie. but who can afford new tyres every session?
What are you talking about?
  • 6 months later...
I don't know anyone that's used them. I think johnny at unique used either these or the similar looking hoosiers that are basically a slick with the minimum number of grooves required to meet DOT approval for road use. however I wouldn't try driving on the road with them, any state in aus and the police would be all over you apart from the fact that any wet weather driving and you'd find yourself in trouble.
on the track though they should be quite good but if you are driving in a class that requires road legal tyres check with the organisers first if they allow these tyres as some road legal classes exclude slicks like this that just have 2 grooves in them.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
