It's for the track only. Would it be classified as a semi-slick or full slick? Only doing track days at the moment, although I would like to be able to enter Time Attack and Supersprints etc.
  • Replies 47
they are not CAMS approved semi slicks. http://www.camsmanual.com.au/pdf/10_gen_req/GQ06_Schedule_E_Q111.pdf
not the same hoosiers that we have seen in Aus before, they might be a new model no-one has requested yet
I've been enquiring about bringing over some Nitto NT-01s through Price USA from Discount Tire Direct. NT-01s are the same compound as Toyo R888s with a more aggressive pattern. They work out at $280 ea posted in a 255/40/17 which is the same price as Federal RSRs here.
If the NT-01's perform anything like the R888, you're probably better off with the Federal RSR IMO.
I had a set or R888s on the 180SX. They were the worst performing semi I've ever used. By a country mile.
Edited by hrd-hr30
what where you using them for? and what was the problem you had with them? Were they new ones or used?
They are the grippiest tyre I have ever used.... however I was using them for motorkhana on concrete on a 1200kg car. My only complaint was they had too much traction - I could not throw the front end a full 180 deg with them on. They had a lot more traction that my Federal RS's - I haven't tried RSR's yet, hopefully they are a bit softer and have more grip from cold.
My understanding is if you are doing circuit work with them it needs to be light (or 'over tired') car, otherwise they get too hot and go off. For short sprints, hill climbs etc they seem to work very well.
Edited by samstain
grippiest tyre compared to what though? have you tried A050s or DZ03G or RE55s? comparing them to federal RS of course they will be better. they should be better than the RSRs too. but for a supposed proper semi they underperform pretty badly. for instance on an R35 GTR which was the last time I used a set they were slower around oran park (RIP) than the standard dunlop high performance road tyres.
No I haven't tried the A050s or DZ03G or RE55s, but I would expect a GG r888 to be gripper than a RSR - especially from cold - to say the 888 is 'the worst performing semi' and not as good as a RSR is a bit out there I would have though without a bit of background on where it was being used.
It depends what you are using them for and the power/weight/tyre size it has...
Fair enough 888's on a high power GTR doing multiple circuit laps are probably going to over heat and go off unless driven very accuratally, however if its a light or underpowered car they can work very well. Likewise if your doing hill climbs and autocross type events they come on very early where as and RSR can take at least a few hard corners to come on - at motorkhana the only time I really got the federals to perform was when my brother was sharing the car with me (2 spots up the queue) and it was a +30deg day.
I had a brand new set of 225/50r16 888's on my S14 for a while and the traction was unbelievable - with careful throttle control it would launch as hard as my brothers 99sti, where as even when new, the RS's were no better than a good road tyre when cold (hopefull the RSR's are slightly better).
anyway, im in the market for new tyres at the moment - tirerack do not do anything suitable for what I want (unless I change to 16" rims in which case I can get AO48's), what other online stores do resonable postage to aus? or has anyone had any luck with forwarding services?
Also, how have people gone with build dates - perhaps in the states turn over is large enough that is isn't a problem, but I'd hate to get supplied 4-5 year old tyres such as what often comes up on ebay in aus.
Edited by samstain
the point is, RSR is not a semi slick, and Toyo 888 is. The Toyo should be significantly faster than RSR, especially if you are using the soft compound.
Federal's semi slick is FZ201.
yep and he was comparing them to the RS which is another step below the RSR. the RS is just a road tyre with the RSR being the kind of 'cross over' high performance road/almost a semi slick type tyre.
either way of the proper semi slicks out there the R888 is way down the list. yes on light cars around 1000kg they perform fairly well but we are talking TRACK (circuit) tyres for skylines (1300kg-1600kg) with anywhere from 250hp to 800hp. the 888s are just not suitable.
I don't know of anyone having trouble with old stock from tyre rack. they are pretty reputable. but you're right, you need to watch out for people shifting 4 or 5 year old tyres as 'new' simply because they haven't been used yet.
The RS is just a road tyre with the RSR being the kind of 'cross over' high performance road/almost a semi slick type tyre.
The only differnece between the 2 is a slightly softer compond (180 V's 140 tread wear from memory) and a slightly stiffer sidewall on the RSR - that and the fact that the RS's are no longer made as far as I am aware, they were superseeded by the RSR a couple years ago. You might be thinking of the SS for thier 'just a road tyre'.
Edited by samstain
Has anybody tried the federal semis?
I;ve been running a set on the race car and they have been very good. hard to tell if they are better than the dunlop without back to back testing on the same day on new tyres....but I'm happy enough (especially since the price is sensible) that I will keep using them.
they are not generally available yet, hopefully they will be sooner rather than later!
like i said, I haven't run them back to back with the dunlops...
I have run the Federal Hards back to back with the Kumho Mediums, they were 0.3 sec slower at Morgan Park (1.20min lap).....very good result against one of the best softer tyres IMHO
3 years sounds like the edge of acceptable to me. I would be very unhappy if they are track tyres, roadies are probably ok for 3-5 years.
in practice, the amount of light and heat where they are stored are more important than time, but you obviously don't know how they were stored.
and with track tyres, the number of heat cycles (times you have raced on them) is more important than time or storage
The more tyres people buy from the US, the more expensive tyres in Australia will get. You need to support the Australian official importers of the tyres because the more they buy from Japan, the cheaper they can get them for which is why they are cheaper in the US. The more you buy from the US, the cheaper US prices will get in comparison to Australian prices. I really wish stoogebags would stop doing this.
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
    • Keen to see the turbosmart data, to date I've only seen negative things in terms of response for them. Very small sample size though.     Hawkins is a big advocate in his videos of the larger rear housings. I managed to make similar power with a lower spec motor on the smaller .8 rear, keeping decentish spool.  The people he works with now are big power cars compared to mine though, mine really is setup to drive around and enjoy.  I don't have any back pressure monitoring though, so couldn't say if its good or bad on my car, just that it does what I want it to do.   Future I want a higher compression more cubes motor to give a bit more bottom end and hopefully the new g35-1150 gets me to the 850 rear comfortably.  But maybe I won't due to exhaust back pressure.
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
