Wrecking whole front end of an R32, all components except the long engine for sale, post here with what you're after.
Aftermarket Stuff:
R32:
4" Cat-Back Exhaust: $400
Front Strut Brace: $100
Rear Strut Brace: $100
Jap Coilovers (height and damper adjustable), are hard, and go very low: $700
Adjustable Caster Rods: $150
Adjustable Rear Camber Arms: $150
Carbon Fibre Vented bonnet: $500
Recaro Drivers side seat rail (same as most other aftermarket rails): $150
Sparco Drivers side seat rail (same as most other aftermarket rails): $150
Mechanical 1.5 way LSD + housing and half shafts: $950
RB26 Trust Greddy Front Mount Intercooler w/piping: $300
N1 Headlight (driver's side): $200
Nismo 260km/h Speedo: $150
S13:
R32/S13 Adjustable Caster Rods: $150
R32/S13 Adjustable Rear Camber Arms: $150
Universal (for any car):
3" Decat Pipe (S/S): $70
Nismo Gear knob: $50
Short-shifter: $150
Recaro SRIII Reclinable Bucket seat (immac condition): $500
Sparco Rev Fixed Back Bucket seat (average condition, has tears etc) $200
R32/R33/A31 Bride Drivers side seat rail (same as most other aftermarket rails): $150
R32/R33/A31 Sparco Drivers side seat rail (same as most other aftermarket rails): $150
3-Point Harness: $50
MOMO "Race" Steering wheel with Nissan Boss kit: $200
GReddy Guages + sensors (water temp, oil temp, oil pressure): $120ea ($350 for all 3)
HKS EVC IV w/ display: $300
3-Layer Copper Radiator: $300
AVS Model 6, 17x9 +36 (pair): $400
Lightweight Jap Wheels (17x8.5 +35): $250
BBS RS 17x9 +20: $1000
Work Meister 18x9/10: $2950
Stock Parts
R32 GTS(t):
Suspension/Steering
2x Front Sway Bar - $50ea
2x Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
2x Front Camber Arms - $40ea -- PICS
2x Front Passenger side Lower Control Arm - $60 -- PICS
2x Front Complete Hub and Brake Assemblys including everything: $280ea
2x Rear Traction arms - $35ea -- PICS PICS
2x Rear Camber arms - $35ea -- PICS
2x Rear Lower Control Arms - $60ea -- PICS
2x Rear sway bar links w/ Urethane bushes - $15ea -- PICS
2x Rear Hubs - $100ea -- PICS PICS
2x Rear Complete Hub/Brake Assembly's including everything - $170ea
1x Rear Sway Bar - $50ea
1x Rear Subframe - $100
2x Rear Toe Rods (non-hicas) - $35ea -- PICS
2x Rear Toe Rods (hicas) - $50ea
Misc:
2x R32 Gearbox - $500
2x Indicators: $50ea
1x Horn, can be hooked up to any car - $20 -- PICS
2x Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
1x Stock Rear Spoiler (with brake light) - $50 -- PICS
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x RB20 Fuel Pump - $40 -- PICS
1x Igniter Module (breaks down under a lot of heat) - $30 -- PICS
R32 GTR:
Passenger Side seat with rails: $250
Front Grill: $150
R33:
Standard VLSD with housing and Half shafts: $300
R33 Lower Control Arms - $200pr
S13:
Located in SA near Mitcham, can Post Anywhere
https://www.sau.com.au/forums/topic/330069-the-get-me-back-to-japan-sale/
Can you please PM me with your phone number.
I'm interested in the 4" cat back. I'm getting AM Performance to look into an exhaust for me, but if you have a similar one available I'd be keen!
Cheers
  RBLUV said:
any of the rear camber arms branded?
unsure of brand sorry.
  toygtr said:
Can you pm me pics of the bonnet and nismo dash for R32 GTR?
  R-SPEC said:
what colour is the Recaro SRIII? pic?
a few pics of requested items:
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
