Wrecking whole front end of an R32, all components except the long engine for sale, post here with what you're after.
Aftermarket Stuff:
R32:
4" Cat-Back Exhaust: $400
Front Strut Brace: $100
Rear Strut Brace: $100
Jap Coilovers (height and damper adjustable), are hard, and go very low: $700
Adjustable Caster Rods: $150
Adjustable Rear Camber Arms: $150
Carbon Fibre Vented bonnet: $500
Recaro Drivers side seat rail (same as most other aftermarket rails): $150
Sparco Drivers side seat rail (same as most other aftermarket rails): $150
Mechanical 1.5 way LSD + housing and half shafts: $950
RB26 Trust Greddy Front Mount Intercooler w/piping: $300
N1 Headlight (driver's side): $200
Nismo 260km/h Speedo: $150
S13:
R32/S13 Adjustable Caster Rods: $150
R32/S13 Adjustable Rear Camber Arms: $150
Universal (for any car):
3" Decat Pipe (S/S): $70
Nismo Gear knob: $50
Short-shifter: $150
Recaro SRIII Reclinable Bucket seat (immac condition): $500
Sparco Rev Fixed Back Bucket seat (average condition, has tears etc) $200
R32/R33/A31 Bride Drivers side seat rail (same as most other aftermarket rails): $150
R32/R33/A31 Sparco Drivers side seat rail (same as most other aftermarket rails): $150
3-Point Harness: $50
MOMO "Race" Steering wheel with Nissan Boss kit: $200
GReddy Guages + sensors (water temp, oil temp, oil pressure): $120ea ($350 for all 3)
HKS EVC IV w/ display: $300
3-Layer Copper Radiator: $300
AVS Model 6, 17x9 +36 (pair): $400
Lightweight Jap Wheels (17x8.5 +35): $250
BBS RS 17x9 +20: $1000
Work Meister 18x9/10: $2950
Stock Parts
R32 GTS(t):
Suspension/Steering
2x Front Sway Bar - $50ea
2x Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
2x Front Camber Arms - $40ea -- PICS
2x Front Passenger side Lower Control Arm - $60 -- PICS
2x Front Complete Hub and Brake Assemblys including everything: $280ea
2x Rear Traction arms - $35ea -- PICS PICS
2x Rear Camber arms - $35ea -- PICS
2x Rear Lower Control Arms - $60ea -- PICS
2x Rear sway bar links w/ Urethane bushes - $15ea -- PICS
2x Rear Hubs - $100ea -- PICS PICS
2x Rear Complete Hub/Brake Assembly's including everything - $170ea
1x Rear Sway Bar - $50ea
1x Rear Subframe - $100
2x Rear Toe Rods (non-hicas) - $35ea -- PICS
2x Rear Toe Rods (hicas) - $50ea
Misc:
2x R32 Gearbox - $500
2x Indicators: $50ea
1x Horn, can be hooked up to any car - $20 -- PICS
2x Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
1x Stock Rear Spoiler (with brake light) - $50 -- PICS
3x RB20 Coilpacks - $30ea
1x Turbo Timer, very basic timer, manual set - $20
1x RB20 Fuel Pump - $40 -- PICS
1x Igniter Module (breaks down under a lot of heat) - $30 -- PICS
R32 GTR:
Passenger Side seat with rails: $250
Front Grill: $150
R33:
Standard VLSD with housing and Half shafts: $300
R33 Lower Control Arms - $200pr
S13:
Located in SA near Mitcham, can Post Anywhere
https://www.sau.com.au/forums/topic/330069-the-get-me-back-to-japan-sale/
Can you please PM me with your phone number.
I'm interested in the 4" cat back. I'm getting AM Performance to look into an exhaust for me, but if you have a similar one available I'd be keen!
Cheers
any of the rear camber arms branded?
unsure of brand sorry.
Can you pm me pics of the bonnet and nismo dash for R32 GTR?
what colour is the Recaro SRIII? pic?
a few pics of requested items:
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
