  • Replies 66
530 in the morning on the 29 dec 2009 on the way to work in the rain heading north in the right hand lane on the M1 at Springwood. I hit a patch of water on the road doing 100kph and it sent me sideways off the road and into a 20 meter high steel light pole, I kept spinning up the bank along the guard rail until I hit one of the rail posts which sent me spinning back onto the road.I walked away with a sore side and couldnt lift my arm higher than my shoulder for a week. $57000 to fix so they wrote it off.
thats enough to make a man cry :D good to see you walked away relatively ok
Wasn't at the Springwood I live in. Glad you're OK.
This was my car earlier this year. Luckily for me I wasn't the driver. The car was stolen from my house and was going about 80km/h when it hit a prado head-on! obviously a write-off lol The driver was just barely alive only because he was drunk and high
was your car a 4dr r33?, its hard to tell. Did you get payed out?
yea it was a 4 door r33 and i got paid out $10k. minus $500 for excess and minus another $300 as I bought back the wreck from the insurance company. That was with 3rd party fire and theft with 'just car'. It only took 2 weeks for them to pay me out as well which I was very happy with :D
this is what happened after a nasho run a few years back. its my brother in laws car, we both worked for a demolition company at the time so we had a yard and a workshop to strip it (had a 2.5L import motor and dog box + suspension work). enjoy!
post-13452-1283764908_thumb.jpg post-13452-1283764915_thumb.jpg post-13452-1283764921_thumb.jpg
post-13452-1283764927_thumb.jpg post-13452-1283764933_thumb.jpg post-13452-1283764940_thumb.jpg
post-13452-1283764945_thumb.jpg post-13452-1283764954_thumb.jpg post-13452-1283764959_thumb.jpg
Wow, there are some nasty crashes in here...and a hell of alot of escape artists...
Here's (one of) mine, for which I was in the front passenger seat...I didn't buy any lotto tickets because I had a feeling I had used up all my luck on this one.
:P What happened?????
Not wrong you are one lucky guy, what happened?
Oops sorry, there is a bit of a pub story to go with that!
We were on a spirited midnight drive through a mountain pass in what used to be a 1.6 litre Pulsar (~165fwkw). Mate had just installed a rear sway bar, so he wasn't used to the oversteer in a FWD...driving way too fast for his ability. We slid out on a corner and he over-corrected (trust it to happen on a corner with no guard rail), then slid off the edge of the road / a hill into pitch blackness. I remember alot of darkness and alot of swearing. We rolled over 3-4 times down a hill and bounced off 2 trees, landing upside down. Ironically, the seatbelt started to slowly choke me, so it was a desperate scramble for the release buckle. I pulled out my phone to call a fire truck and dropped it onto the roof, which doesn't usually happen :)
I would have waited for the fire truck but I had no idea where we were and the fear of every action movie's upside down car fire/explosion scene made it very easy to snake crawl through the broken glass (didn't feel it cutting in!) and that rear window^^^. The ambos told us they had seen some bad accidents in their time and did not expect survivors when they rocked up to this one. I was at the gymnasium the next day though :(
from the pics i think i know exactly where this is - i've nearly put my skyline into the centre divide a few times in the wet, it has the poorest drainage around springwood.. that coupled with crap roads, its a death trap.. I can barely manage 80km/h in the wet going through springwood.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
