OK guy's, i have an R32 GTR, that's getting oil in the water both in the rad and in the overflow bottle
not a huge amount maybe 30-40 mill's every 400k's
engine is running fine, no misse's, no smoke, done comp and leak down test's, 150 in all 6, leak down is
3-4%, not bad for a donk with 120k's, rad pressure test show's nothing, oil pressure is fine also..
i'm not loosing oil or water, and it's only oil in the water no water in the oil..
any idea's??, i'm at lose!, have i cracked a head or block??, or is it something simple and common??
was thinking i may check the water cooler around the oil filter base, see if that's crack or corroded..
and idea's or prevous experence's would be greatlly appreciated
cheers Jon
https://www.sau.com.au/forums/topic/330109-oil-in-water-r32-gtr/
If it's not the headgasket, it could possibly be the factory oil cooler (oil warmer, oil/water heat exchanger whatever you want to call it) is leaking as it deals with the engine coolant and engine oil.
this is what i'm checking tomorrow, i cant' see it being a head gasket, it would have shown up in the leak down and
comprestion test's...
  • 3 weeks later...
I had the same problem before my rebuild. Was a hairline crack in the block for me.
It had oil in the radiator, and overflow bottle, and was originally thought to be the head gasket. Further investigation proved otherwise.
Hope this isn't the case for you, could be expensive :thumbsup:
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
    • I've been quietly following this thread for ages, but this one got me. Since my ADHD diagnosis (and associated learnings and prescription) I'm way less inclined to wade into forum yarns when there are better things to do with my time, as half the time I'd end up in some kind of forum debate even if that wasn't my intention. I've not lost the ADHD "superpowers", just am a lot better at directing my hyperfocus into slightly more constructive things, but haven't stopped quietly lurking in here in my spare time.
    • Stripped the tank down and gave it a good scrub. It came up really good! Not sure if I'll just put it back in like that or give it a blackening treatment (such as Bowdens The Black Box). That might give it a matte look so might just run it as is.
    • @MBS206 Ha ha, yeah ADHD is a daily battle to not get drawn in to doing things you want to do that you know you shouldn't do!  Every single time I walk into my shed I end up doing something I started the day having zero intention of doing! I keep mentioning the 1 step forward, 3 steps back scenario and I'm tipping people that are blessed with ADHD (yes, blessed) are the worst at that!
    • We import a lot of cars from Japan. I'd say that approximately 20% of our traffic is imported JDM cars (mainly consumer cars like the Mazda Demio, Toyota Yaris, Honda Fit, Suzuki Swift, etc.). We also import a lot from the UK, but this has decreased after Brexit. Apart from the consumer vehicles, two of the larger, well-known dealerships frequently import iconic '80s/'90s JDM cars. I haven't heard of anyone importing from Australia, and they are not advertised (unlike Japanese ones), despite a lot of Maltese migrating to Australia in the '50s and '60s.
