My good friiend is keen on this car , Are the injectors maxxed out , what PSI do u run (be honest) , HKS turbo's are great for high boost what do you run on day to day also when ur ringing its neck??
$23 500 is a lil steep , but well worth it if its a good quality example..
  • Replies 41
Hi Blu32GTR, the injectors will only spike over 80%, only over by 3 or 4 percent. The dual stage boost controller has its standard setting on about 12 psi, and with the launch switch activated the car runs on 19-20 psi. The guys at unique auto sports have set all this up on the dyno and I havent tampered with it, except to turn the boost down a couple of pounds as the days have gotten hotter.
Its just had a new (reconditioned) engine put in under 3k ago, spent over 6 grand and have reciepts for all the work done. reason for replacement engine was incorrect tuning for australian fuel, (modded ecu in Japan) and new tune via power fc is healthy and clean. If price is too much for you I will sell cheaper with standard mags, there is over $15000 worth of extras alone on this car so I think price is reasonable,
Hi again,
the injectors are standard as far as I know, as is the fuel pump. The 265's are michelin sports and they have about 60% life left in them. They are a good tyre though, and I haven't seen any wear since I brought them 3k ago, second hand when I got the mags. the fronts are only 5% worn if that, and have heaps of life left in them. 216 rwkw was made @ top boost, at about 6000rpm. Obviously the pneumatic turbosmart system is inferior to an electronic boost controller and the ebc will net a better power figure and curve when installed and tuned correctly. You can pick up a boost control kit for the powerfc which is excellent and allows boost changes via the hand controller. They are about $450 down here, but they may be a little cheaper up in qld..?
shan
If you look at the dyno sheet it actually made 216rwkw @ only 13psi....which is very impressive, if the turbo could be sorted to hold boost to redline it would probably make and extra 30rwkw....might be as easy as a HKS actuator $150 from greenline.
Nice car, great buy.
Hey BOOSTD your right, I just figured out that I've been looking at the sheet wrong the whole time!! Yeah The car still has lots of potential, may as well go electronic boost controller that should fix the problem, although HKS actuator would help with this setup soon.
yes, boost comes on quick, you gotta be very careful in the wet. I love the response of this turbo. Ive raced a Datto 1600 which had 190 rwkw (and was considerably lighter) but just couldnt get me because boost didnt come on for him until the last 2500 rpm in his rev range. Lag sucks huh? Anyone want to hazard a guess as to what sort of power increase I would get with an extra 7psi up top?
"$23 500 is a lil steep" please keep the comments to pm only and not in the main post. Steep? based off what?
1993 r33 gtst manual for $17000 with 60,000 on the clock +
Apexi bar and plate intercooler $1200
HKS gt2530 ball bearing turbo $2000
exhaust, including wastegate split dump pipe $500
18 inch Chrome DTM's with 265 rubber on the rears $2000 at least
GTR bodykit (front 400r bar, side skirts, GTR wing) $1000
Autometer boost gauge + Tomei air fuel gauge - mounted on dual side pillar pod $500
suspension
Short shift kit $400
Performance 6 puck Clutch $800 at least
HKS turbo timer $150
Apexi powerfc with hand controller $1500
Pioneer mp3 cd player $500
GFB stealth bov $350
HKS pod filter $200
Turbosmart boost controller with rocket launcher switch $300
spare R33 GTR front bar $500
$28,900
and you get all that tuned (which costs a lot too) for $23,500
no i dont know this person, merely pointing out that some people expect to much
still think its steep?
those are very conserative prices and dont include fitting and turing
intercooler supplied and fitted will be around 1600, the turbo would be $2500 fitted (or more)
and it looks as though he is using a Tanabe Racing Medallion muffler. Which arent cheap too..
Yes Tanabe muffler it is. Thanks paul, its nice to have someone point this out besides myself. Pics sent to mike J, but email is full... empty and I'll send you more
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
