Urgent Skyline R34 25 Gt-t Over 100000 Kms Worth The Money
Sorry Guys I am a bit confused now about Turbo Vs non-turbo. I definetly need a 4 door but as you guys suggested that 13K is a bit steap for sedan GTT with 118000kms.I was thinking to go with 2000 R34 GT 4 doors then for around $11000 with RWC unregistered.But still it wont be Turbo so no point of having skyline without Turbo???.
4 doors are only 20kg heavier. To me, a 2dr is f**king stupid in GTT form. 2 door = GTR or GTFO (my opinion) You wont lose any performance in the long run (someone correct me if I'm wrong), and you will be thankful every time you go near the rear doors.
f**k i am confused now. I like the turbo but what do i do with it.It would give me satisfaction when i drive it but do i need a turbo?Also what do you guys think about maintainence of turbo vs non-turbo and resale value.
Resale value of a N/A is almost zero. GTT sedan (and GTT in general) is fast becoming almost zero. Get a turbo, and wait and spend the money on a nice one so you don't have regrets later on. Its a buyers market, so be a smart buyer.
You know most that is "unregistered" is a fresh import, therefore, initial rego fee = $1000+ :D
As for turbo vs NA, depends on what you want, if you don't care about the little kick when boost kicks in and just wants a car to get from point A to B, then NA will do the job, but if you like to have a bit of fun sometimes, then turbo is the way to go.
Maintainence - depends on the condition of the car I guess, anything that's in a shit condition will cost you more at the end :) But I guess an NA will be cheaper to maintain and cheaper on fuel, but not much difference, maybe 1-1.5L per 100km.
I think you should not rush it, look around and wait for a good one to pop up. But again, definitely get it with RWC and rego.
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
