Got A Problem
607CHA
 Share
Hey just wondering if anyone could help me with my problem. i have a hcr32 rb20det i just put new oil and a set of plugs in today took it for a spin and on high boost (apexi avcr) during boosting it's like its leaning right out or something not really sure had to pin point the problem. I checked all the boost and vacum lines and cant find anything off. but runs fine on low boost. Could it possibly be the spark plug gap or oil or something? or maybe the avcr but never happened before the plug and oil change.. All help would be greatly appricated.
Thanks matt
Yes its your plug gap.
Well it might be. Do you want to share with us what plugs you put in and what gap? Were they the same as the plugs you pulled out and what gap did they have?
NGK Laser platinum PFR6A-11 went into it and NGK R PF7B came out. jsut put in what autobarn sold me... not sure on gaps. What gap would be recomended?
Thanks.
Gap to 0.8 and ull be fine. Be careful when gaping non copper plugs as the tips are delicate. FYI you are not meant to gap them.
Next time you will remember to check the gap.
Most people go for copper plugs [NGK BCPR6ES] because they are cheaper and you can easily replace them annually. I would guess that your old plugs had quite a big gap but would be worthwhile to find them and measure the gap (if you haven't got a set of feeler guages they are not dear).
If your coils are old and tired it seems to pay to gap your plugs down to 0.8mm instead of the stock 1.1 BTW I am not sure if it is platinums or iridiums that don't like being gapped so be carefull and if you break an electrode just bite the bullet and get a set of coppers and try to sell your remaining 5 plugs!
This may not be your problem though. Did you do everything back up tight (since you have to pull quite a bit off to get to the plugs)?
All Good advice thanks heaps ill try and gap them right just gotta buy a gap thingy lol. I checked and double checked everything was back on right so ill try tomorrow and just hope for the best and hope nothing breaks. cheers
Edited by 607CHA
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
