Anquetil Posted January 28, 2004 Share Posted January 28, 2004 Been wanting to relocate the CC to the back of the engine bay on the passenger side to make way for a CAI box. However, after taking a closer look I noticed a line (D) coming off the base of the CC which seperated into 2 lines, these 2 lines where like rails which went to the rear of the engine bay and followed the dump pipe out of sight. Anyone know what these are? Do they just vent to atmo down there? I dont want to remove the canister altogether. Link to comment https://www.sau.com.au/forums/topic/33018-r33-relocating-the-carbon-canister/ Share on other sites More sharing options...
51jay Posted January 31, 2004 Share Posted January 31, 2004 Would't you just cut them off just befor they go under the firewall and use fuel hose and joiners to bring them back to your new location, I don't think any just vent to air Link to comment https://www.sau.com.au/forums/topic/33018-r33-relocating-the-carbon-canister/#findComment-667675 Share on other sites More sharing options...
Anquetil Posted February 1, 2004 Author Share Posted February 1, 2004 Did this yesterday, as you said I just cut the lines off near the firewall. The line I was talking about actually vented to atmo, half way down the exhaust. Link to comment https://www.sau.com.au/forums/topic/33018-r33-relocating-the-carbon-canister/#findComment-667786 Share on other sites More sharing options...
|PRESA| Posted September 11, 2004 Share Posted September 11, 2004 Whats wrong with actually disabelling the canister all together? Link to comment https://www.sau.com.au/forums/topic/33018-r33-relocating-the-carbon-canister/#findComment-1009024 Share on other sites More sharing options...
NewKleer Posted September 11, 2004 Share Posted September 11, 2004 its required for emissions, so removing is illegal (big fines accompany it) legalities aside, removing it means you are releasing fuel vapour into atmosphere, rather than being taken into the intake and burnt like normal air/fuel would. youll get slightly worse fuel consumption, but some people report better performance. in the end, if u can keep it without too many hassles, then do so. i also relocated mine to back corner of engine bay, passenger side. Link to comment https://www.sau.com.au/forums/topic/33018-r33-relocating-the-carbon-canister/#findComment-1009210 Share on other sites More sharing options...
predator Posted September 11, 2004 Share Posted September 11, 2004 i always assumed they went back under the car there so they vented back into the fuel tank? Link to comment https://www.sau.com.au/forums/topic/33018-r33-relocating-the-carbon-canister/#findComment-1009262 Share on other sites More sharing options...
NewKleer Posted September 11, 2004 Share Posted September 11, 2004 theres only one line from the tank, thats the vapour line shown as C above. the D line only needs to vent to atmosphere. once your greater than about 2k rpm, the vaccum line is activated which opens the valve, drawing the stored vapours in the charcoal thru the intake. i *think* the vent line (D) draws air from outside the car for which the vapour travels in to intake. either that or the D line vents clean air once vapour is removed out to atmosphere, or possibly both of the above. Link to comment https://www.sau.com.au/forums/topic/33018-r33-relocating-the-carbon-canister/#findComment-1009292 Share on other sites More sharing options...
