1998 R34 GT-T
  • Full 3.5 turbo back zorst with dump
  • High flow pod filter in cold air box
  • Manual turbosmart boost controller set at 12psi
  • Lowered on adjustable coilovers and sitting on lightweight volk 18s
Hi all, looking at getting a Nistune type 4 board for the above car (stock R34 ECU) got qouted $282 from Nistune.com in Adelaide. Does anyone have Nistune on R34 with the above mods or similar??
If so, what are their experiences / recommendations?? Is it a good thing with a nice tune?? If so, how long's the average tuning time - I'm just looking for a daily streeter with a sharp punch.
Any cheap but good tuning workshops in Sydney (I'm in Parra) - dyno guys who have Nistune exp and know their stuff??
Noob question - I have my stock turbo - is 12psi too much?? I've read varied opinions some say keep it 10, others say max 13 or even 14, but I know they blow at 14, so is 12psi okay??
Thanks - any help much appreciated
https://www.sau.com.au/forums/topic/330189-nistune-for-r34-gt-t/
I had mine with very similar mods running on 11psi with the NIStune. Really happy with it!
Does everything and was a quick tune because it's already got the base map there to start with. I got 216rwkw i think on that setup.
Now last dyno was at 266rwkw with turbo, afm and injector upgrades, it's higher now but i dunno what it's at atm... NIStune doing a great job with that tune as well :thumbsup:
Best bang for buck by far when it comes to ECU's
it really depends on how rich or lean your car is. if your running really lean on high boost for those turbos then it will blow from getting too hot.
r33 stock turbos are quite finicky. if you really like your turbo id suggest investing in getting it hi-flowed and then you wont have to worry.
Im running a Nistune,
3inch exhaust turbo back, FMIC, Stock turbo..
boosted to around 16psi ( i know what your going to say!!! lol )
Car went from 150ishkw to 221KW. Massive upgrade.
Im not to worried to much about the turbo as its not my daily driver and i want to upgrade the turbo set up
I got mine done down at Envy Imports at brookvale, totally happy with it,and the guys down there are awesome.
Hi guys, many thanks for the awesome feedback, I reckon Nistune is a good go from what all I've been hearing about it, do you suggest upgrading my stock GT-T intercooler before going Nistune??
I dont intend to do additinal mods like turbo/injector/fuel pump etc, just guna keep it at stage 1 mods. And 'Random_I_Am', did u have any flat spots before Nistune and did that get cured after? Hows the car to drive before and after Nistune?? Differences, response etc.
My ones very sharp and responsive from down low, around 2.5k RPMS to around 4.7 or 4.8k k, then I get that nasty lag or flat spot from 4.8k to 5.7k or something, after that, the turbo hits its hardest (quite strong) all the way to 7k RPMS. Find it a bit strange..
So is tuning time roughly 2-3 hours for the R34 and do the workshops do the soldering of the board to the ECU?
cheers RON
You'll say goodbye to this with NIstune
My rule of thumb is you don't need a bigger intercooler unless and until you get a bigger turbo.
i put on a fmic, made a massive difference with throttle responce, then put a exhaust on, helped it flow alot better.
Nistune is a awesome unit, id hate to be the one putting the boards together.. have to soldier 36 or 40 pins to the main ecu..
yeah the flat spot was tuned right out with nistune, unless of course the flat spot your feeling is coil packs... but you'd surely know about it then if it was.
car went from memory 180rwkw before, then after the tune was 216rwkw. and smooth as hell :P
i had blitz FMIC beforehand.
the unit really isn't hard to solder up either, i did mine in well under an hour...
Edited by Randon_I_Am
Wow Random_I_Am, ur saying u got like 36Kw power gain with the board and tune, thats awesome, I dont have a fmic,. and EJD001 you getting a massive gain in throttle response could be something to do with you running 16psi? 16psi on stock turbo and you still going sweet, makes me kinda relieved as I thought my 12psi was a bit much.
From what I'm hearing the stock cooler is good for 200rwkw max (or is it 220rwkw??) and a lotta people with the same mods as me are seeing around the 220rwkw mark with a nice board n tune which I dont have yet..
So still dunno if I should bother with a fmic, as I heard it also creates lag with the longer piping. Are the return flow ones much better? :P
My car is booked in for tuesday to get nistune installed and tuned i will get it back on wednesday will let you know how it goes
Hi mate, i have an r34 gtt aswell, also in need of tune and am leaning in the same direction with nistune.
I had a look at nistune.com and it says the type 4 board is $460.00
How much is it costing you to get installed and tuned???
There is no more lag with a FMIC i don't reckon... I used a Blitz Return Flow type and if anything it felt more responsive than the stock one?
as for gaining 36kw, They were off the top of my head. I just had a quick look and i got 214.6rwkw on 11psi.
When i rolled in the AFR's dropped straight off the chart it was so rich with the factory ECU.
Well thing is the actual board just by itself no software ect only costs 260. For 460 i think you also get the software so you can tune it yourself.
I have been quoted between 770-850 supplied fitted and tuned. The variation in price is dependent on if there is any major issues that take a long time to work through (particularly when it is getting tuned) at least that is what he said even though i will happily pay 850.
Another very happy nistune user here. Just front pipe back exhaust, 10psi using turbo tech bleed valve, trust turnflow intercooler made 190rwkw. Seemed a bit low compared to others, but car drives very very well! Super smooth. Been almost a year now and have had no issues at all.
$460 I think is for the software licence (which you dont need ) plus board - the tuner should have the software; for the board alone I was quoted $282
Correct, the $460 is for a Type 4 board AND a single User license, you only need this license if you want to tinker with your car after its' been tuned (or you want to tune it yourself).
Edit: Can someone with a MANUAL R34 GTT, give me the part number for their ECU please? I need to order a board for someone that has lost the sticker off their ECU.. it will be a 27xxx-xxxxx kind of number.. TIA!
P.S. if anyone in Perth is looking to get a board, PM me :P
Edited by bubba
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
