1998 R34 GT-T
  • Full 3.5 turbo back zorst with dump
  • High flow pod filter in cold air box
  • Manual turbosmart boost controller set at 12psi
  • Lowered on adjustable coilovers and sitting on lightweight volk 18s
Hi all, looking at getting a Nistune type 4 board for the above car (stock R34 ECU) got qouted $282 from Nistune.com in Adelaide. Does anyone have Nistune on R34 with the above mods or similar??
If so, what are their experiences / recommendations?? Is it a good thing with a nice tune?? If so, how long's the average tuning time - I'm just looking for a daily streeter with a sharp punch.
Any cheap but good tuning workshops in Sydney (I'm in Parra) - dyno guys who have Nistune exp and know their stuff??
Noob question - I have my stock turbo - is 12psi too much?? I've read varied opinions some say keep it 10, others say max 13 or even 14, but I know they blow at 14, so is 12psi okay??
Thanks - any help much appreciated
https://www.sau.com.au/forums/topic/330189-nistune-for-r34-gt-t/
I had mine with very similar mods running on 11psi with the NIStune. Really happy with it!
Does everything and was a quick tune because it's already got the base map there to start with. I got 216rwkw i think on that setup.
Now last dyno was at 266rwkw with turbo, afm and injector upgrades, it's higher now but i dunno what it's at atm... NIStune doing a great job with that tune as well :thumbsup:
Best bang for buck by far when it comes to ECU's
it really depends on how rich or lean your car is. if your running really lean on high boost for those turbos then it will blow from getting too hot.
r33 stock turbos are quite finicky. if you really like your turbo id suggest investing in getting it hi-flowed and then you wont have to worry.
Im running a Nistune,
3inch exhaust turbo back, FMIC, Stock turbo..
boosted to around 16psi ( i know what your going to say!!! lol )
Car went from 150ishkw to 221KW. Massive upgrade.
Im not to worried to much about the turbo as its not my daily driver and i want to upgrade the turbo set up
I got mine done down at Envy Imports at brookvale, totally happy with it,and the guys down there are awesome.
Hi guys, many thanks for the awesome feedback, I reckon Nistune is a good go from what all I've been hearing about it, do you suggest upgrading my stock GT-T intercooler before going Nistune??
I dont intend to do additinal mods like turbo/injector/fuel pump etc, just guna keep it at stage 1 mods. And 'Random_I_Am', did u have any flat spots before Nistune and did that get cured after? Hows the car to drive before and after Nistune?? Differences, response etc.
My ones very sharp and responsive from down low, around 2.5k RPMS to around 4.7 or 4.8k k, then I get that nasty lag or flat spot from 4.8k to 5.7k or something, after that, the turbo hits its hardest (quite strong) all the way to 7k RPMS. Find it a bit strange..
So is tuning time roughly 2-3 hours for the R34 and do the workshops do the soldering of the board to the ECU?
cheers RON
You'll say goodbye to this with NIstune
My rule of thumb is you don't need a bigger intercooler unless and until you get a bigger turbo.
i put on a fmic, made a massive difference with throttle responce, then put a exhaust on, helped it flow alot better.
Nistune is a awesome unit, id hate to be the one putting the boards together.. have to soldier 36 or 40 pins to the main ecu..
yeah the flat spot was tuned right out with nistune, unless of course the flat spot your feeling is coil packs... but you'd surely know about it then if it was.
car went from memory 180rwkw before, then after the tune was 216rwkw. and smooth as hell :P
i had blitz FMIC beforehand.
the unit really isn't hard to solder up either, i did mine in well under an hour...
Edited by Randon_I_Am
Wow Random_I_Am, ur saying u got like 36Kw power gain with the board and tune, thats awesome, I dont have a fmic,. and EJD001 you getting a massive gain in throttle response could be something to do with you running 16psi? 16psi on stock turbo and you still going sweet, makes me kinda relieved as I thought my 12psi was a bit much.
From what I'm hearing the stock cooler is good for 200rwkw max (or is it 220rwkw??) and a lotta people with the same mods as me are seeing around the 220rwkw mark with a nice board n tune which I dont have yet..
So still dunno if I should bother with a fmic, as I heard it also creates lag with the longer piping. Are the return flow ones much better? :P
My car is booked in for tuesday to get nistune installed and tuned i will get it back on wednesday will let you know how it goes
Hi mate, i have an r34 gtt aswell, also in need of tune and am leaning in the same direction with nistune.
I had a look at nistune.com and it says the type 4 board is $460.00
How much is it costing you to get installed and tuned???
There is no more lag with a FMIC i don't reckon... I used a Blitz Return Flow type and if anything it felt more responsive than the stock one?
as for gaining 36kw, They were off the top of my head. I just had a quick look and i got 214.6rwkw on 11psi.
When i rolled in the AFR's dropped straight off the chart it was so rich with the factory ECU.
Well thing is the actual board just by itself no software ect only costs 260. For 460 i think you also get the software so you can tune it yourself.
I have been quoted between 770-850 supplied fitted and tuned. The variation in price is dependent on if there is any major issues that take a long time to work through (particularly when it is getting tuned) at least that is what he said even though i will happily pay 850.
Another very happy nistune user here. Just front pipe back exhaust, 10psi using turbo tech bleed valve, trust turnflow intercooler made 190rwkw. Seemed a bit low compared to others, but car drives very very well! Super smooth. Been almost a year now and have had no issues at all.
$460 I think is for the software licence (which you dont need ) plus board - the tuner should have the software; for the board alone I was quoted $282
Correct, the $460 is for a Type 4 board AND a single User license, you only need this license if you want to tinker with your car after its' been tuned (or you want to tune it yourself).
Edit: Can someone with a MANUAL R34 GTT, give me the part number for their ECU please? I need to order a board for someone that has lost the sticker off their ECU.. it will be a 27xxx-xxxxx kind of number.. TIA!
P.S. if anyone in Perth is looking to get a board, PM me :P
Edited by bubba
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
    • Dad had a court case drag out with them from 1998 to 2004. He was in a not at fault accident, NRMA were the ones who covered the other person. They tried to blame his neck injuries on the fact he'd had an injury in 1981 on his extreme lower back where he slipped a single disc right near the bottom. Had been all cleared from that injury for years. This accident destroyed his shoulder, and f**ked a heap of discs in his neck, and he still has major problems with it to this day. Sarah's sister while on her L plates had a small Suzuki Alto, she had stopped to give way to an ambulance, and someone changed lanes behind her because there lane was also slowing, and rear ended her at 80km/h. (She had been stopped for a few seconds already too!). Car was completely f**kED. NRMA sent the vehicle around to 3 different workshops as they kept claiming "We believe it can be repaired, and not written off, we just need to find the correct workshop". It took 3 months, and a lot of arguing before they'd concede and wrote it and paid out. About two years later her sister had a Lancer, someone pulled out of a stop sign without stopping (in an 80 zone). Her sister swerved, hit the front of the other persons car (Instead of dead t-boning the drivers door), which ramped her Lancer, and made it roll multiple times down the road. It hit every panel on the way through. Her sister had slid her self out of the car, and remembers the ambos walking to the accident (They'd been sitting at a set of lights just down the road and witnessed it) and they were saying "Well, this ones going to be a fatality, no way you can walk away from that". Well, she did. And then NRMA sent two assessors out to look at the car, both of which wrote it off. They tried to send another assessor out, except a HUGE uproar was raised, and they FINALLY paid it out. That was on a car, that had damage to EVERY panel, you could see from 100m away the whole car was also twisted, roof bowed etc. Nah, we'll try get out of needing to payout on a $10,000 car... Her sister ended up with major shoulder reconstructive surgery being required, and was permanently limited in her ability to do her job as a nurse after that, as she can't (And was told before surgery too this would be guaranteed to happen) regain full strength in that shoulder. However, there was no choice to not have it, as she could barely use her arm, which was her dominant one, and was in near constant major pain. (And she's the type of person that would try and walk off a broken leg!) NRMA did the biggest run around on the personal injury side too for about 18 months, even to the point of trying to put 100% blame of the accident on Sarah's sister, even though the other driver admitted she didn't look, and didn't stop, and was charged by the police. Sarah used to have a Barina insured with them. It was a policy setup, paid all 12 months in advance. At the end of the 12 months, Sarah was living with me, I reviewed the renewal, it clearly stated "If you do nothing, your policy will cease on XYZ date". We did nothing, as we moved her insurance in with all of mine and I was with Shannons. We find out 10 months later, NRMA decided, because he DAD had a car insurance policy at the same address as what Sarah's mailing address was (Garaged address had been changed), that they'd put Sarah's (What should have been non existent policy) onto her Dad's month to month charges on his credit card. We had to jump through hoops, to get a refund. They didn't care that we actually found the letter that said "If you do nothing, your policy will cease" they made us prove we had NON COMPULSORY insurance else where before they'd issue the refund, and after they agreed to the refund, it still took another 6 weeks and 3 more phone calls for them to actually process it. They also had two insurance claims from storm damage, and they were an absolute cluster to get resolved as well (one vehicle, one house). Some how, up until about 3 years ago, her parents were still loyal to NRMA too, and we were like "How the hell are you so loyal to staying with them, when other places are so much cheaper, and they've f**ked you over every time you've ever had to make a claim?"
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
