1998 R34 GT-T
  • Full 3.5 turbo back zorst with dump
  • High flow pod filter in cold air box
  • Manual turbosmart boost controller set at 12psi
  • Lowered on adjustable coilovers and sitting on lightweight volk 18s
Hi all, looking at getting a Nistune type 4 board for the above car (stock R34 ECU) got qouted $282 from Nistune.com in Adelaide. Does anyone have Nistune on R34 with the above mods or similar??
If so, what are their experiences / recommendations?? Is it a good thing with a nice tune?? If so, how long's the average tuning time - I'm just looking for a daily streeter with a sharp punch.
Any cheap but good tuning workshops in Sydney (I'm in Parra) - dyno guys who have Nistune exp and know their stuff??
Noob question - I have my stock turbo - is 12psi too much?? I've read varied opinions some say keep it 10, others say max 13 or even 14, but I know they blow at 14, so is 12psi okay??
Thanks - any help much appreciated
https://www.sau.com.au/forums/topic/330189-nistune-for-r34-gt-t/
I had mine with very similar mods running on 11psi with the NIStune. Really happy with it!
Does everything and was a quick tune because it's already got the base map there to start with. I got 216rwkw i think on that setup.
Now last dyno was at 266rwkw with turbo, afm and injector upgrades, it's higher now but i dunno what it's at atm... NIStune doing a great job with that tune as well :thumbsup:
Best bang for buck by far when it comes to ECU's
it really depends on how rich or lean your car is. if your running really lean on high boost for those turbos then it will blow from getting too hot.
r33 stock turbos are quite finicky. if you really like your turbo id suggest investing in getting it hi-flowed and then you wont have to worry.
Im running a Nistune,
3inch exhaust turbo back, FMIC, Stock turbo..
boosted to around 16psi ( i know what your going to say!!! lol )
Car went from 150ishkw to 221KW. Massive upgrade.
Im not to worried to much about the turbo as its not my daily driver and i want to upgrade the turbo set up
I got mine done down at Envy Imports at brookvale, totally happy with it,and the guys down there are awesome.
Hi guys, many thanks for the awesome feedback, I reckon Nistune is a good go from what all I've been hearing about it, do you suggest upgrading my stock GT-T intercooler before going Nistune??
I dont intend to do additinal mods like turbo/injector/fuel pump etc, just guna keep it at stage 1 mods. And 'Random_I_Am', did u have any flat spots before Nistune and did that get cured after? Hows the car to drive before and after Nistune?? Differences, response etc.
My ones very sharp and responsive from down low, around 2.5k RPMS to around 4.7 or 4.8k k, then I get that nasty lag or flat spot from 4.8k to 5.7k or something, after that, the turbo hits its hardest (quite strong) all the way to 7k RPMS. Find it a bit strange..
So is tuning time roughly 2-3 hours for the R34 and do the workshops do the soldering of the board to the ECU?
cheers RON
You'll say goodbye to this with NIstune
My rule of thumb is you don't need a bigger intercooler unless and until you get a bigger turbo.
i put on a fmic, made a massive difference with throttle responce, then put a exhaust on, helped it flow alot better.
Nistune is a awesome unit, id hate to be the one putting the boards together.. have to soldier 36 or 40 pins to the main ecu..
yeah the flat spot was tuned right out with nistune, unless of course the flat spot your feeling is coil packs... but you'd surely know about it then if it was.
car went from memory 180rwkw before, then after the tune was 216rwkw. and smooth as hell :P
i had blitz FMIC beforehand.
the unit really isn't hard to solder up either, i did mine in well under an hour...
Edited by Randon_I_Am
Wow Random_I_Am, ur saying u got like 36Kw power gain with the board and tune, thats awesome, I dont have a fmic,. and EJD001 you getting a massive gain in throttle response could be something to do with you running 16psi? 16psi on stock turbo and you still going sweet, makes me kinda relieved as I thought my 12psi was a bit much.
From what I'm hearing the stock cooler is good for 200rwkw max (or is it 220rwkw??) and a lotta people with the same mods as me are seeing around the 220rwkw mark with a nice board n tune which I dont have yet..
So still dunno if I should bother with a fmic, as I heard it also creates lag with the longer piping. Are the return flow ones much better? :P
  Marcus89 said:
My car is booked in for tuesday to get nistune installed and tuned i will get it back on wednesday will let you know how it goes
Hi mate, i have an r34 gtt aswell, also in need of tune and am leaning in the same direction with nistune.
I had a look at nistune.com and it says the type 4 board is $460.00
How much is it costing you to get installed and tuned???
There is no more lag with a FMIC i don't reckon... I used a Blitz Return Flow type and if anything it felt more responsive than the stock one?
as for gaining 36kw, They were off the top of my head. I just had a quick look and i got 214.6rwkw on 11psi.
When i rolled in the AFR's dropped straight off the chart it was so rich with the factory ECU.
Well thing is the actual board just by itself no software ect only costs 260. For 460 i think you also get the software so you can tune it yourself.
I have been quoted between 770-850 supplied fitted and tuned. The variation in price is dependent on if there is any major issues that take a long time to work through (particularly when it is getting tuned) at least that is what he said even though i will happily pay 850.
Another very happy nistune user here. Just front pipe back exhaust, 10psi using turbo tech bleed valve, trust turnflow intercooler made 190rwkw. Seemed a bit low compared to others, but car drives very very well! Super smooth. Been almost a year now and have had no issues at all.
$460 I think is for the software licence (which you dont need ) plus board - the tuner should have the software; for the board alone I was quoted $282
Correct, the $460 is for a Type 4 board AND a single User license, you only need this license if you want to tinker with your car after its' been tuned (or you want to tune it yourself).
Edit: Can someone with a MANUAL R34 GTT, give me the part number for their ECU please? I need to order a board for someone that has lost the sticker off their ECU.. it will be a 27xxx-xxxxx kind of number.. TIA!
P.S. if anyone in Perth is looking to get a board, PM me :P
Edited by bubba
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
