Hey,
We are in the process of gathering ideas on what is missing in the auto performance industry in relation to adapters/flanges!
If you have required an adapter that you couldn't find let us know.
This may relate to adapters for BOV's or anything else you may think off...
All feedback will be greatly appreciated... and if possible include images :thumbsup:
Thanks,
Brendan
  Jetwreck said:
Thanks!
We will have a look into fuel rail adapters - seems like a great product.
- Brendan
  GTScotT said:
Fuel rail conversion kits to suit R33 side feed injectors converting to top feed items such as Seimens deka.
Thanks,
Do you have a link to an image/description of the actual product?
- Brendan
  tricstar said:
just had to make my own adaptor to go from 90mm to 120mm v-band to v-band, don't know if anyone currently makes these.. garrett told me it would be a custom item.....
Thanks,
Do you have any images of the actual item?
-Brendan
  VultureMotorsport said:
Thanks,
-Brendan
Nah and its on the car now...
we just took the 90mm v-band take off that comes with the turbo and a disc cut at 120mm diameter with 90mm hole in the middle, with the appropriate angle around the outside for the v-band and welded them together...
so we v-band the back of the turbo to the 90mm flange which steps up to 120mm and v-bands to the 120mm dump.. all within the space of about 30mm
hope this make sense, I'll see if I can get a picture of it on the car
cheers
Thanks,
- Brendan
Sorry mate, I couldnt link you to another product for obvious reasons.
What I am refering to is merely a fuel rail that will fit an R33 RB25DET motor using top feed injectors from a R32 GTR (for example).
What you would hope to acheive is a product that fits with minimal modification and comes with all parts necessary to install the set injector (bar the injectors themselves).
This would mean the rail would require the fittings for the fuel lines, and come with new o-rings where required along with mounting hardware.
The MAIN requirement is that the set will fit the motor with its factory intake inplace, there ARE products such as these on the market at present yet generally they do not fit with the factory intake in place.
Thanks mate,
We actually offer an RB25DET fuel rail with a top feed injectors set-up but again it's for the GReddy plenum only - we will look into it though.
- Brendan
  briggsey said:
Making up an adapter plate for rb26 intake plenum to be used on rb25, I think blitz make one but they are rare
Already made. Shane made them ages ago. We are about to run off some on the mill for our own race car...
off topic, how about a full bolt-in oil cooler kit with thermostat, all the correct brackets/bolts/hoses cut to length, hose mounting points, plastic conduit for the braided lines so it won't rub against things and a price that's reasonable.
We do stock an oil cooler w/ filter relocation kit, but yes it does not come with a thermostat and a lot of customers do seem to want one.
- Brendan
Thanks mate,
- Brendan
Indeed you do, make that fit the stock manifold and at that price they will sell like hotcakes.
Another item I would like to see available is an exhaust side spacer plate that is reversible to switch between RB25 and RB26 bolt patterns.
the concept is simple, an bolt through the plate replaces the original studs in the end exhaust ports that are different, and a stud presses in from the opposite side to accept the alternate bolt pattern.
By reversible I refer to both sets of bolt holts being able to accept a stud or bolt from both sides to make it easily reversed for the opposite application. Longer studs for the middle 4 cylinders will be needed to be supplied with the kit.
This could see people converting to RB26 setups from their failing 20 or 25s without having to replace expensive manifolds, or could see more twin turbo setups floating around too.
- Brendan
Yes that is true, but it's not a full bolt in solution, the end-user/buyer needs to fabricate their own brackets, cut and shut the oil lines to length, etc..
  bubba said:
What about an adapter to bolt RB25 GRreddy plenums to RB20 heads?
Some great ideas... now we just need to find a good fabricator to get things rolling with a sample product.
Any recommendations would be great!
- Brendan
- Brendan
Can't help on the fabrication but if you need any 3D modelling done shoot me a PM :P
