Im on the sunny coast and been looking for an exhaust system for my 89 skyline executive sadan and having trouble finding one...
dose anyone know where i can get one????
thanks
just go to any exhaust shop and get them to knock one up for you
Pretty much, i got a set of extractors here if you want a set. $80? I'm on the northside of brisbane. can send pics if you want
i got a set of extractors off ebay said RB30 nissan and when i got them found out they were off a vl!!! will they fit straight on or do i have to mod them??? how much do u think ill have to fork out to get a custom one made?? thanks
VL ones normally don't line straight up onto a 31, cat bolts sit at a different angle and i think it even sits a slightly different angle, although if you get the rest of the system made/fitted at an exhaust shop they will work no worries at all, seen them used heaps of times.
Custom headers are pretty expensive, i would expect to see up around $1000 a set
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
