Hey guys, just wondering what you guys think about this...
Have a weird repetitive sound, sounds like metal on metal. Happens when im driving at any speed, and if im driving in a straight line, and nudge or turn the steering wheel right it goes away but still continues if i turn left. Had also a bit of a bingle with a gutter on that wheel a few months ago though just started happening constantly 2 weeks ago.
Whats a way to diagnose if its the actual wheel bearing again?
Thanks again
Edited by silbastian
https://www.sau.com.au/forums/topic/330237-wheel-bearing/
Yeah i did that last week and they seemed to be fine. I think i may have found the problem though going to check the front brakes tomorrow. All this time i had been thinking that there was plenty of meat left as i had replaced them last year though realised now i did the rears not the fronts *facepalm* my friend was standing at the front of my house, and could hear it at least a good 80metres way... thank god they didn't seize. :(
https://www.sau.com.au/forums/topic/330237-wheel-bearing/#findComment-5365680
re-checked nuts and that today, and also the brake pads. the fronts look brand new.
in the process of this i also found that my front right tie rod end bush was split in half and collapsed. but i doubt that would make the sound.
anyone else have an idea?
clutch - yeah im thinking its that again... dam!
https://www.sau.com.au/forums/topic/330237-wheel-bearing/#findComment-5370628
the bearing is a pretty easy fix, i wouldnt stress to much!
https://www.sau.com.au/forums/topic/330237-wheel-bearing/#findComment-5370657
Also get your park (hand) brake serviced/re-greased - it may not be retracting properly after many years.
I had the same problem on my R34.
Had all my brake pads changed and rear rotors machined - the tech noticed the park brake system sticking.
He gave it a clean and a grease - no more problems.
https://www.sau.com.au/forums/topic/330237-wheel-bearing/#findComment-5372733
i actually experienced that the other day! was parked on a hill and said handbrake was engaged though when i put my foot of the brake started to roll
https://www.sau.com.au/forums/topic/330237-wheel-bearing/#findComment-5372790
LOL.
I think you should always park the car in gear....
https://www.sau.com.au/forums/topic/330237-wheel-bearing/#findComment-5373031
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
