I am wanting to buy some rims off a mate but my current hub centric rings are too big and the manufacturer doesn't reply to emails. They wouldn't be hard to make. The bit on the hub measures 66mm and the rim measures 70mm. I'm guessing thats something like ID 66.1mm OD 69.9mm. That or somewhere to buy them in the right size. Have only found limited sizes on ebay.
Thanks.
https://www.sau.com.au/forums/topic/330247-where-to-get-hubcentric-rings-made/
if you want metal (aluminium or steel) and they're not available on fleabay you can try some wheel and tyre places, or go to an engineering or machining place and ask them to spin up a set on the lathe to your tollerances.
I took an R32 GT-R wheel in to a Fyshwick engineering place and they made up 20 hub centric rings (five sets for myself and other MR2 owners) to fit GTR wheels to Toyota MR2 hubs (60.1 to 66.1). The rings are the right size and fit well but they made them out of the easiest material (steel) instead of aluminium as requested, be sure to be specific about materials and if you can, leave a wheel with them for the duration. cost was 11 per ring inc. GST so $44 for the set plus a bit of time and efforts priming the steel to prevent rust.
PM for details of workshop - not that i recommend them too highly after they changed materials without consent.
