Currently running 0.5degrees toe out on front, 8/6kg springs, rose jointed caster arms, lock subframe, no hicas, adjustable whiteline sway bars, ISC coil overs 2.5 degrees rear camber, 2.5degrees front camber
Am thinking to add some rear traction arms, camber arms front and rear, and possibly nolethane bush the lower control arms.
Is there anything I can do for the steering rack mounts, are there bushes or what ever I can buy to get it abit firmer as on lower speed tracks with heavy cornering the steering can become quite heavy.
Is there anything I can do to the subframe to beef it up? The car is tight, but its not as tight as i'd like it to be, cornering at 200k's there is quite abit of play.. ( has a full rollcage)
Is anyone willing to point me in the right direction in terms of alignments etc, or any advice to tighten it up. Currently doing 1.08s around Pukekohe NZ.
https://www.sau.com.au/forums/topic/330271-r33-race-alignment-settings/
I'm certainly no expert, but il chip in my 2c.
if its a track based car, i'm tipping your on semi's?
anyhow, 2.5 -ve degrees up front maybe isnt enough, I run atleast 3, mostly 3.5 and mine see's the road once a fortnight atleast. (not many kays tho)
on the rear, 2.5 -ve sounds to be too much, i only run 1.5 -ve on the rear.
you dont mention ride hights, but the "recomended" ride hight for gtst's is 350mm front, 340mm rear, thats from guard/top of wheel arch to centre of the hub.
nolethane bushes are a good idea for the rear LCA's.
adjustable front and rear UCA's is a good idea (rear traction rods also), and front LCA's are handy also.
what type of diff? stock? shimmed? or 1.5/2 way?
as for steering maybe 'new' tie rods & rose jointed tie rod ends?
and for track work, depending how serious you are, most people would recomend ditching the ISC coilovers. I'm in the process of ditching my teins for bilstein shocks (with extra hight adjustment grooves) and king springs (6.5ish Kg & 4.5ish Kg).
0.5 toe out up front sounds okay, what you running on the rear?
hope this helps, Jack
Cheers for the reply.
Rear has neutral toe , any suggestions. Am running full 17inch slicks. Still running standard diff, its rubbish, am trying to find a 2way, past experienes with shimming diffs is they dont last long enough. Height wise i will check, however it looks similar to your car in your photos, e.g. not very low. Will have a play with camber.
I will look into nolathane bushes for rear RCA's, there doesnt seem to be a part number for front however, is there no bush in the front arm or? What are your toe settings.. Thanks :D
I will look into nolathane bushes for rear RCA's, there doesnt seem to be a part number for front however, is there no bush in the front arm or? What are your toe settings.. Thanks :P
dont be shy with the diff mate. a open wheeling factory spec diff is totally bloody shithouse. even if it doesnt last forever, its still better than open wheeling and lasting forever lol. as for toe, I'm running 0 deg. in/out on the front with 3mm of total rear toe in on the rear.
AFAIK you'd only want to add rear toe in if you needed to deal with rear end instability - otherwise you'd leave it alone. Toe in = reduced tendency to change direction. Dont forget to check out the handling articles sticky above.
Regarding bump steer, the relationship between lower control arm and rack end/tie rod, angle wise, is the main factor there. If you can get them to 'follow the same arc" through suspension travel you should eliminate bump steer.
As for camber, 2.5deg neg camber is not enough on the front if running slicks. I know a guy in an n/a falcon who races at Lakeside here in Brisbane with 6deg neg camber on the front and wears front tyres evenly, he pushes mighty hard though.
If I was to set up my R33 for circuit racing using slicks I'd have 3.5-4deg neg camber on the front with probably 0 toe, maybe 2deg neg camber on the rear with about 2mm toe in. About 8deg positive castor on the front and traction arms would be adjusted according to trial and error on the track and ride height.
^^ Thanks alot, gives me a good starting point. Appreciated. What are your thoughts on running a locked diff as opposed to standard lsd, is the understeer part going to play quite a major role in the cars handling? Ive driven some 2 way lsd's and its pritty much like driving a lock diff anyway,
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
