Hey guys... has anyone experienced this b4?
It seems like since this afternoon, everytime when I start my car and engages it into 1st gear for the first time, after the car goes for awhile, there's this little cranking noise coming from the front.
There's no power loss and no other issue in terms of performance and it never happens again after that until I off the car and restart it. I haven't tried switching off the engine and immediately restart so not sure if it only happens on a cold engine.
Anyone has this issue before? My car comes with a complimentary pre-inspection report from the AA which will be done on Tuesday so I'll get the inspector to have a look and see if he can identify the issue as if there's something wrong, the dealer will need to sort it out.
Really hope it's not a big issue as apart from this, the car is going real smoothly and I am really enjoying it everytime I drive it!
Hmmm dunno mate. Let us know how the inspection goes!
I would say its sounds like the bendix gear on the starter motor isn't fully disengaging
and clipping the first tooth on the flywheel
and if its more the gearbox do a fluid change on the box with a top quality fluid
Edited by Cra-Z-Boy
From what I heard, it's the ABS doing a self diagnostic when you go over 20km/h from a cold start and completely normal.
Sound is like a grinding noise and worried me before i found that out.
Hey Peter, sounds exactly like what you describe mate! And yes, the noise came around the 20km/h mark. Another of my worries solved by you excellent people here! Thanks man! Honestly, if you didn't tell me, it does sounds a little scary and hence quite worrying for me... so really appreciate the update!
Chris, thanks for your update too! This may be a real dumb question but as someone who has limited knowledge on cars, where is the transmission fluid tank located? Is it the same as the power steering fluid tank? Thanks!
Edited by win4ever
Are you guys driving an automatic or a manual?
I'm driving an 04 semi-auto, I get that exact same sound too. Glad to hear it's normal!
Hey Siglapian,
Yes, mine is a Nov 04 semi-auto as well, so i guess it's something that is normal for all of us! And yes, I am glad to hear it's normal too! :(
It is normal mate, more noticeable in a cold start. My car does that too and at first i thought it was something wrong then I read the manual and it says something like a self check thing on start up.
Thanks Alvin for the update! That's just great! Seems like I was not the only one that got worried when I first hear the noise then! :) Well, that's another reason why i just love this forum! The knowledge sharing availability here is just fabulous!
I have an 02 GT8 and it has always done it but never really chased down an answer as I had that theory, if you just rest your foot on the brake pedal you can feel it pulsating in conjunction with the noise.
Mine will also do it when hot and I have just come out of the shops.
Hmm, I've noticed sometimes when I use the brakes for the first time after starting the car it almost feels like the ABS being activated?
I'll have to pay more attention and see if it is the same as what you guys are describing here.
Hi Guys
Im just new to the forum and this is my first post. Getting used to replying etc.
I have an 08 Skyline 370GT S 6 speed manual and i get the same thing. When its cold theres almost like a cluncking noise coming out of the gear box, nothing serious or loud, no loss of power etc and when i picked it up she only had under 8k. I've looked into it and its normal for these boxes to be a bit louder, even when im changing gears from 1st to 2nd its a bit cluncky. Maybe i should take a 370z for a drive and see if its the same.
Does anyone else have a v36 here? if so let me know so we can chat further.
Cheers
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
