Hi
This is a HICAS problem and before anyone comes in and says it, no I dont want to lock it because the problem I have can be fixed pretty easily i think lol
Ok basically
put a MOMO steering wheel on a while ago with a Works Bell boss kit and it was fine around town, no problems. I went on a highway drive and after 15mins HICAS light comes on. So basically i worked out what I had done wrong was when i put the boss kit on I didnt line up the correct holes on the back with the Hicas locating tab an plug on the steering sensor.
So Ive fixed it now but the problem I have is that my stock steering wheel was off to the left a bit (say 5 degrees to the left while Car is driving straight) and the HICAS light wasnt coming on then so im guessing that the HICAS thinks that at that point where the stock steering wheel is was 0 degrees when it was actually to the left about 5 degrees
So just wanted to know if I'm right and this means im going to have to adjust the sensor 5 degrees to the right so the steering wheel is straight and if so how do I do that?
I thought I would have to pull the steering shaft out of the rack and rotate it 1 tooth to the right to fix the problem but i dont think that is the solution as I now believe the sensor will need to be adjusted
So if anyone has experience in this I would be very happy to hear your results
Thanks Guys
Callan
https://www.sau.com.au/forums/topic/330292-hicas/
What you need to do is have the front wheels facing dead straight to start with. Then take off the steering wheel. Then align the arrow on the clock spring (steering sensor) to the arrow on the housing. Then adjust the plastic collar in the middle of the sensor assembly to line up with the holes in the steering wheel boss. This is the blinker self cancelling collar. Then install steering wheel and it should then be straight.
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5365125
thanks for the reply
when u say arrow on the clock spring.... is this arrow visible with just the steering wheel + Boss kit off? cause all i could see was the hub that the boss kit turns on (with the prong to align the hub in the steering wheel/boss kit and plug for the horn)
Or do i have to pull the steering colum surround off to see/adjust the sensor position?
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5365154
ah ok sweet
I may have to take the surround off to adjust the sensor behind the rotating ring that the boss kit locates in, but they alignment marks so i can get them both top centre with wheels straight and they will be fine? if thats the case then im all sweet
Thanks for your help mate
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5365169
kinda worked out the alignment, theres a sort of indented line in the top of the sensor and i figure the nissan logo on the ring should be the right way up so just have to get steering wheel and it should be straight... will know friday if it has fixed my problem :D
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5366935
Hey guys, im just about to pull iff my steering wheel and replace the sensor.
Sorry to hijack your thread, but is there any chance that im going to deploy the air bag when im pulling the steering wheel off? Is there a certain sequence for taking it all apart?
Has anyone changed the sensor before? I have done a diagnostic on the hicas and it says no signal from steering angle sensor. I dont even know where to buy a replacement??
Any info will help
Thanks
Blake
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5368447
Hey Blake. There are 3 plastic covers on the steering wheel cover. 2 at the sides for the airbag bolts and one underneath for the electrical connectors. Take the bottom cover off first and undo the two electrical plugs. Then undo the two airbag bolts. You will need a T50 Torx bit to do that. Then lift out the airbag. Then undo the steering wheel bolt and lift the wheel off. Undo the steering shroud and you can then get to the screws that hold the sensor on. Its pretty easy to do. I just did mine also and just bought a new sensor from Nissan. Its not cheap but just think of the age of s/h ones. I dont think its worth buying a s/h sensor. Then its just reverse of how it all came off to fit it.
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5368903
I would be wondering why the stock wheel was sitting 5deg left :D
it was like that when i bought it from the dealer.. Think it had aftermarket steering wheel on before import and they just got the stock steering wheel back on as good as they could? just never bothered fixing it
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5368923
Sounds more like your whole wheel alignment is out.
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5369025
it is out a little but not that far lol
I just think it had been a bit of a rush compliance job or something cause it had no horn on it when i bought it either, someone had forgotten that I had to tell the dealer to put one on
It needs a wheel alignment anyway, will have to get done soon
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5369063
The column runs what, a 25 spline? If it's out a tooth, it's going to be 15 degrees out... not 5.
5 Degrees would be an alignment issue, most likely the car is crab walking when you drive it.
https://www.sau.com.au/forums/topic/330292-hicas/#findComment-5369471
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
