  • 1 month later...
finally decided to do this today and i must say Im not a fan of this setup at the front,
the way it sticks out from the caliper. I'm tempted to get an angled fitting to fix it ..would of been much better utilizing the factory line to the caliper with another female adapter at the bracket..but oh well..
Also did you tie it up at the back at all, i was thinking a little bracket to hold it up to that bolt where the original bolted up..shouldnt be too hard
all in all went well, I didnt have any wd40 left so i took a chance and just gave them all a love tap with the hammer and was all set to brag about not rounding any until the very last one got the better of me..1 out of 8 isnt bad i guess..had to get the vice grips on it and it let go with a snap, it was stuck good...still didnt round it though so it will go back together fine..:D
Anyway, i trust nobody has encountered any problems with theres yet..
:cheers: Phil
I thought the same thing when i put mine in.
Hasnt been an issue mind you. Out of sight, out of mind :)
Heres hoping one day it doesnt come back to mind when i lean on the brakes and the pedal meets the floor.
  • 1 year later...
  • 1 year later...
Does it matter if I empty out the master cylinder. Or is there a way to stop all the fluid flowing out of the master cylinder.
I'm trying to avoid having to bleed the master cylinder after it goes too low
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
