Hey guys.
Started my car up on friday morning, in which it felt like absolute shit. The traction light was on, slip light was on, and the check engine light was on. WHILE IN IDOL.
Shaky as anything like a cylinder was completely missing. Turned the car off and started it back up, it disapeared.
Then while i was driving, it happened again, lights back on, and a very unstable car.
We checked the coilpacks which ive had for about 9 months now, new yellowjackets, and removed 1 lead at a time as the car was running and it was the exact noise which it had been making.
we ended up finding that it was number 6 not doing anything, so we took it out and placed in in the spot of number 1, after this, 6 was ok and 1 became the problem.
Is this a common thing and why did the stated lights appear?? do i have a ecu problem, im going to get in touch with my coilpack supplier as one is buggered.
Appreciate the help guys.
https://www.sau.com.au/forums/topic/330310-dropped-a-cylinder/
Hey guys.
You've answered your own question... if swapping the coilpack to a different cylinder moves the problem to that cylinder, you could be fairly confident that its the coilpack that is causing the problem.
I've had one of them fail recently. I'm interested to find out if there are any others.
Have you got the yellowjackets aswell??
Im confused as to why the traction lights were on while in idol, any ideas???
Howcome the traction light were on aswell, i can understand the check engine light lol, because its not sparking. Any ideas???????
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
