BRAND NEW.. Blitz active twin plate clutch for R32 GTR (Pull type).The BLITZ Active Clutch was designed to hold maximum horsepower while retaining daily drivability. Weights 15-20% lighter than stock. Cost $2200. Selling for $1600 ono.
GARRETT 2860'7 Used for few thousand Km's. Great nik. $1700.
Nismo Le Mans Group A turbos RR581's.60/48. Smaller exhaust side for quik spool up. Rebuilt and havn't been used. Look new. Rare turbos..$1500.
BRAND NEW.. Blitz 700CC injectors. Still in there sealed plastic and boxes. These retail for $1100 at nengun. Fit straight in to RB26. Selling for only $700. This is for all 6 of them.
HPI dumps. 3 inch. These are stainless steel and will last forever. Similar to tomei dumps. Retail for over $1K. Selling used but great nik $550.
Apexi Power FC. Used but good nik. Comes with hand controller $700.
GTR torque split converter. Turn ur GTR from 2wd to full 4wd with the flick of the dial. Retail for $230. BRAND NEW. $150.
Sard fuel pressure regulator. Used but great nik $90.
https://www.sau.com.au/forums/topic/330338-gtr-partsmelbourne/
willing to COD the SARD reg to sydney? if so ill take it... if i end up getting it might take the dumps off you aswell.
Edited by Hiroshima Screamer
more info please which is better bigger and straight fit ? how much kw ruffly a stock engine with power fc can it push
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
