BRAND NEW.. Blitz active twin plate clutch for R32 GTR (Pull type).The BLITZ Active Clutch was designed to hold maximum horsepower while retaining daily drivability. Weights 15-20% lighter than stock. Cost $2200. Selling for $1600 ono.
GARRETT 2860'7 Used for few thousand Km's. Great nik. $1700.
Nismo Le Mans Group A turbos RR581's.60/48. Smaller exhaust side for quik spool up. Rebuilt and havn't been used. Look new. Rare turbos..$1500.
BRAND NEW.. Blitz 700CC injectors. Still in there sealed plastic and boxes. These retail for $1100 at nengun. Fit straight in to RB26. Selling for only $700. This is for all 6 of them.
HPI dumps. 3 inch. These are stainless steel and will last forever. Similar to tomei dumps. Retail for over $1K. Selling used but great nik $550.
Apexi Power FC. Used but good nik. Comes with hand controller $700.
GTR torque split converter. Turn ur GTR from 2wd to full 4wd with the flick of the dial. Retail for $230. BRAND NEW. $150.
Sard fuel pressure regulator. Used but great nik $90.
https://www.sau.com.au/forums/topic/330338-gtr-partsmelbourne/
willing to COD the SARD reg to sydney? if so ill take it... if i end up getting it might take the dumps off you aswell.
Edited by Hiroshima Screamer
more info please which is better bigger and straight fit ? how much kw ruffly a stock engine with power fc can it push
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
