Going to NZ on Wednesday so super cheap prices ONLY until midday wednesday 25/08..........
NISMO TURBO'S------ ONLY $ 1200
BLITZ CLUTCH------ ONLY $1350
Be quik ppl's. These prices are strickly only till this date.
Thought i replied but now that i look nothing has come up.. Sorry mate.. Ummm well i bought this thinking it was a pull type and someone on here told me by lookin at the pic it was a push type.. I'm selling the clutch as is in the picture. New and never used.
Yes you did reply and then I replied back but now both replies are gone. Weird. Anyway what I said was I thought Push type clutches came with conversion kits to go from a Pull type to a Push type clutch, which is what the OS Giken push type clutch I thought did. But you said it's just the clutch only that you have. That's all.
Cheers.
Cheers.
I don't know. I thought you just buy the right clutch for your requirements. But then you can get conversion kits if need be.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
