hey my climate control in my r33 hot and cold adjustment doesnt seem to be working anymore... :|
it did use to work.. lol
it seem to blowing hot air all the time even when set to 18 degrees
it still blows hot air with a/c on and with changing the fan speed.
any ideas were to start?
https://www.sau.com.au/forums/topic/330353-r33-climate-control-issue/
hose has come off behind the dash or the plug fell out. To the left of the steering where theres a little vent on the dash, theres rubber hose that connects to it and a small plug with a resitor in the end of it. The AC uses this to work out what tempreature it is inside the cabin. without it it just defaults to full hot.
Pull your dash out and check that there both pluged in.
Jack
Jack
+1
I had this exact issue once when I pulled my dash out and forgot to plug the sensor back in... full hot all the time :(
but i havent touch or pulled anythin out of the dash....
so i dont c how it came out or undone.. :blink:
i noticed last nite, i turn it the air on straight away..and set it to 18 degree,
and even after my temperature went to normal,
and i adjust the the temp to 32 degrees it felt lik 18 degree still...
so i actually think that the hot/cold buttons...
well what that goes to is jamming and is not working properly....
is ther a servo/motor that i can check out, and if so wer is it? lol
  • 5 months later...
bumb...
i found this...of another topic..
"Given you just had work done done on the car I'd say the ambient sensor is unpluged ( it should be the little black lump next to the horns, behind front bumper).
Like GTScotT said its a common thing, mechanic forgets sensor, A/C thinks the outside temp is -40C or something and fires up the heater 4 ya
There are 2 other sensors, one at the back of the dash ,left side (sunLoad) and one just to the left of the steering columb (interior temp).
Any of these left unpluged/faulty will screw up ya AirCon (usually with the heat your gettn) "
"have a search on SAU for heater threads you should find plenty of info on the heater. being a 33 owner I'm not familiar with the 34 BUT if ya stick ya head under the glove box and hit the 'recircualte air' button, you should see a 'rod and lever' arangement mo0ving, thats the cowl door. Same goes 4 the heater cores tap, change the temp and something will move to direct the water flow.
like I said though do a search. I'm sure I've seen full removal guides and all. "
bump..
did you look at the ambient air temp sensor? or the cabin air temp sensor?
Check these, doesnt matter if you havent been doing anything to those areas, things happen, wires come loose or go bad. Just check.
Search for Air-Con diagnostic mode. Its on here some where but im lazy to find it. You hold down a button when you turn the ignition on and you can see which sensors etc arnt working
Otherwise check the hot/cold blend servo to see if its stuck or broken.
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
