Hi Guys
Im running a group buy on AM Performance Blast pipes. they will be twin 4 inch pipes with angled up tips and a straight cut on the end of the pipe. they will have a single 3 or 4 inch entry (depending on your exhaust diameter) and available in muffled or straight thro configuration,
Put simply they look awesome and are high quality items.
Basically once you have the pipes you'd head to your nearest reputable exhaust shop and get them to weld it on and mount it with a couple of hangers... the blast pipes cant be supplied with welded on hangers due to the many different configurations out there.
I will be doing an order of 5 or 10 if i can get enough interest. But it will work like this.
5 orders, straight thro blast pipes $280 each or muffled $310 each
10 orders, straight thro blast pipes $250 each or muffled $280 each.
rrp is around 380 normally.
I will be running this for one month.. or earlier if i can get all the spots filled. but what i will need is payment and addresses of each order and then they will all be sent out. there will be a start and finish date for this buy. Start will be today and finish date will be 26/08/2010 or earlier if all 10 spots are filled. If i only have enough interest for 5 buys then i will go ahead with that and process the order earlier then the finish date.
People Interested
(updated with interest)
now for some pics so you all know what im talking about.
https://www.sau.com.au/forums/topic/330404-am-performance-blast-pipes/
Quality stuff guys, I've got a full exhaust from AM Performance on my car and the quality is second to none! Free plug for a great bloke!
+1, im over the moon with the full system andrew did for me :bigthumbsup:
Interested.
Whats the full width of these pipes and the lenght? Gotta make sure it fits thru the gap in my rear bar. Also shouldnt matter if the exhaust is put on the right hand side un like the pic up above on the left.
Edited by siddr20
hey mate.. doesnt matter if its left or right hand side as they are made symmetrical. width of the two pipes is 210mm and length is ROUghly 560mm.
also have added details up top. only 4 spots left
keen as simon for prob the muffled one.
does the muffled one change the look of it at all or is it internaly muffled?
cheers man
Edited by Import S13
  • 4 weeks later...
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
